Attaching brass script to Radiator
Posted: Wed Jul 10, 2024 1:06 pm
by bdtutton
I have decided to add a little bling to my car and attach a brass "Ford" script and a small "1914" script to my radiator. There are two recommended ways of attaching the script. They say you can use brass wires to hold the script to the radiator or you can silver solder the brass script to bolts and run the bolts through the radiator. I was wondering if anyone had any advice or feedback on this issue.
Thanks...Bryan
Re: Attaching brass script to Radiator
Posted: Wed Jul 10, 2024 1:13 pm
If you go with the wire-on method, put a small, matchstick sized piece of hardwood on the back side of the radiator and attach your wire to that.
(An actual matchstick may not be strong enough to hold up over time. Maybe a piece of a kabob stick would be best.)
Posted: Wed Jul 10, 2024 3:45 pm
by bdtutton
Adding support on the back side of the radiator is a good idea. I was concerned that you would be able to see the wires, but if the wire is made out of brass like the letters it should blend in. Has anyone used the silver solder method on bolts through the radiator? That one worries me because I don't know if you have to bend the fins on the radiator to get the bolts through.
Posted: Wed Jul 10, 2024 5:08 pm
by DaveBarker
When I did mine, I soldered brass wire sets onto the back of the brass script and ran the wires through the honeycomb radiator I had on the car. Worked well, but the above advice is good; use a small piece of wood for backing. Twisting the wire ends might damage fins.
Posted: Wed Jul 10, 2024 5:12 pm
The only way that will work is the bolt method. Threaded welding rod should do. Brass wire will soon wear and break. VOE. Since I learned that all that stuff is incorrect I don't bother with it.
Posted: Wed Jul 10, 2024 8:51 pm
I use 3mm {1/8"] stainless steel allthread and brass acorn nuts. One nut wound on to max depth on outer end, another on the inside. I make a small metal plate for the inside, backed with a glued on piece of inner tube rubber, to protect the radiator fins and maintain a modicum of tension in the assembly. Use loctite to help keep the inner nuts in place.
You can use stainless nuts to match a plated script.
Posted: Wed Jul 10, 2024 8:52 pm
by Dennis Prince
I wired mine on with small brass wire that my wife uses in her art work to hold it while the silicone sealer set up that I put on the back (not a lot but enough to hold it), that way I don't have to worry about vibration and it can be easily removed.
Posted: Thu Jul 11, 2024 11:31 am
Why do something that isn't correct in the first place?
Posted: Thu Jul 11, 2024 11:33 am
bdtutton wrote: ↑Wed Jul 10, 2024 1:06 pm
Thanks...Bryan
Whatever you use I would sleeve it with a piece of neoprene tubing to prevent the wire/bolt from rubbing on the radiator fins. It may not be necessary at all but then....
Posted: Thu Jul 11, 2024 2:08 pm
by csnailnrun
Original Smith wrote: ↑Thu Jul 11, 2024 11:31 am
Why did muscle car owners add Go Wings or Cragars?
Why do Jeep owners add big mud tires and led lights?
Why do people add bumper stickers to their cars?
Why do new home owners repaint & change fixtures?
Why do gun owners accessorize their toys?
BECAUSE THEY CAN AND WANT TO!
Here’s a thought: How about you leave people be? That’s sounds pretty “original” to me.
Posted: Thu Jul 11, 2024 2:22 pm
by RVA23T
csnailnrun wrote: ↑Thu Jul 11, 2024 2:08 pm
- 6873473395_97ff320acc-4094526911.jpg (53.64 KiB) Viewed 2389 times
Posted: Thu Jul 11, 2024 2:50 pm
by Erik Johnson
Cragars aren't just for muscle cars.
In the 1960s, my great uncle put Cragar S/S wheels on his 1959 Cadillac Sedan de Ville.
Posted: Thu Jul 11, 2024 3:31 pm
by rbishop26
I went with Allan's method. Drilled two small holes thru the brass script, put the threaded rod thru with the cap nuts. Only difference is I added a washer under the cap nuts on the inside of the radiator to protect the fins. It's been 20 years and no problems.
