1913 Speedster, a 3-Generation Build
Posted: Tue Jul 30, 2024 8:54 pm
by AEyssen
Starting a build thread to track the progress of a “new” speedster build by an enthusiastic 16 y/o, his dad who will document the process (me), and his Model T part supplier & MTFCA past prez grandfather (@tmdltim).
First step was a trip to Texas and home of Cast Iron Automotive where 95% of the parts were pulled off dusty shelves and laid out on the shop floor.
The heart of the car is a restored & running 1913 engine from the late Prestley Morris. Already 060 over, it will get a high compression aluminum head and specialty carb.
Re: 1913 Speedster, a 3-Generation Build
Posted: Tue Jul 30, 2024 8:59 pm
by JTT3
Congrats this is going to be fun! Thanks for letting us follow your progress. Best John
Posted: Tue Jul 30, 2024 9:02 pm
by AEyssen
Step 2 was driving all the parts & pieces 19 hours to North Carolina. There, the parts will get the usual prep, paint, and assembly.
But not before the method of dropping the frame a few inches is determined and fabricated.
Posted: Tue Jul 30, 2024 9:28 pm
by AEyssen
Parts arrived home and work is ongoing (at least until school starts in 3 weeks). Follow along here or on Instagram @diyluke
Posted: Tue Jul 30, 2024 10:10 pm
by tdump
Glad to see the younger 1's taking a liking to the T's!
Posted: Tue Jul 30, 2024 10:32 pm
by TeveS-Nor Cal
Going to be a fun series of posts. Keep em coming!
Posted: Tue Jul 30, 2024 11:53 pm
by Chris Instness
Looking forward to seeing the progress!
Posted: Thu Aug 01, 2024 8:56 pm
by AEyssen
Rough mock up continues. Aux transmission will get a custom bracket and married to an already shortened drive shaft. Lowering steering column angle next priority.
Posted: Fri Aug 09, 2024 5:56 pm
by AEyssen
Front spindles coming together. Sanded, primed, painted, clear coated, and new bushings installed.
Posted: Fri Aug 09, 2024 7:57 pm
by DHort
Remind him that he will be most comfortable if he tilts the seats back about 10-15 degrees. Wish I had done it with my speedster.
Thank you for the post. I will enjoy reading it.
Posted: Fri Aug 09, 2024 11:27 pm
Laying the seat back helps, but it still needs to be positioned correctly for the individual driver's comfort. If it is a bucket seat installed individually on the body base, you could consider more than one set of mounting points so it can be shifted at will.
Posted: Fri Aug 09, 2024 11:58 pm
by Powerwagonmaniac1
Glad to see the next generations build. Carston are having so much with "Nuthin' Special" his little ' 23 rpu. Check out his build thread under Nuthin Special for some inspiration. Dad and Grandpa good on you guys passing it on!
Posted: Sat Aug 10, 2024 5:39 pm
by AEyssen
Great looking build. Will check out your thread!
Posted: Sat Aug 10, 2024 6:30 pm
by AEyssen
More gears! The speedster will have a Muncie aux transmission. Luke cut, welded, and painted a support bracket.
Posted: Tue Aug 13, 2024 5:57 pm
by Mark Nunn
The spindle arm nut should not be tightened onto the spindle until after the front suspension is assembled. The tie rod's bolts will dictate the position of the arm on spindles. Tightening before final assembly will guarantee binding.
Posted: Tue Aug 13, 2024 7:56 pm
by JTT3
Luke & Alex if you have not planned to put auxiliary brakes on your speedster, I strongly recommend you do so since you are putting in an auxiliary transmission. Using period auxiliary transmissions or rear axles make it imperative to do so. If they jump out of gear or your locked out from shifting into a gear puts you in a bad situation with no real way to stop. I’m enjoying the build & progress keep up the good work.
Best John
Posted: Wed Aug 14, 2024 2:21 am
by Craig Leach
Great to see the younger generations get into the hobby. I built a 1966 Chevy pickup with my granddaughter best time ever!!! Muncie as a great
choice, with reverse you can eliminate the low peddle & lower the steering column even more. I hate to be a stick in the mud but I would figure
out a trans mount the will allow the frame to flex more than that one will, There should be a drilled & taped hole on the underside of the Muncie
tail shaft that will work very well. Model T frames flex a lot I find it best to not try to stop them from flexing.
Craig.
Posted: Wed Aug 14, 2024 9:32 pm
by AEyssen
JTT3 wrote: ↑Tue Aug 13, 2024 7:56 pm
Best John
Great advice. Yes we heard that there is risk of moving and unable to get back into a gear. We have a set of new Rocky Mountain brakes that will get painted and installed.
Posted: Wed Aug 14, 2024 10:25 pm
by AEyssen
The engine - a ‘13 - will get an aluminum head upgrade. Machine shop cleaned it up before install. New copper head gasket ready too.
Posted: Thu Aug 15, 2024 7:12 pm
by Wayne Sheldon
Fantastic stuff!
Thank you for taking us along.
Posted: Mon Aug 19, 2024 6:35 pm
by AEyssen
The speedster will get a set of wires to accompany its later model running axles. We are ready to make it a roller. But before mounting the new tires, we need to pick a wheel color. Unfortunately these two shades of green aren’t it (left side vs right side).
Posted: Tue Aug 20, 2024 7:17 am
Either of this two shades of green would go well with a vivid yellow body colour.
Posted: Wed Aug 21, 2024 10:12 pm
by AEyssen
Driveline assembled tonight. Luke got the shortened drive shaft bolted up to the Muncie and the rear end. Added new 600W in the process. Fun to see the axles spin with the turn of the hand crank.
Posted: Mon Aug 26, 2024 8:20 pm
by AEyssen
The biggest new purchase so far is the birch firewall. Stain and polyurethane added before it gets bolted up to the chassis this weekend.
Posted: Sun Sep 01, 2024 7:32 pm
by AEyssen
First wheel mounted. Decided on black color. Three more to go then we will have a roller.
Posted: Sun Sep 01, 2024 8:47 pm
Alot easier to mount tires on wire wheels whilst on the car !
Posted: Mon Sep 02, 2024 12:03 am
Fitting tyres that way gives valuable experience. Now he knows how to do it, he is well set.
The even easier way is to have a tyre shop do it. My fellow puts a little electrical tape on the four "grippers" to protect the paintwork. The mounting head goes around the wheel 1/8" above the outer edge of the rim, so no paint damage there either. 10 minutes per wheel, done and dusted!
Posted: Mon Sep 02, 2024 4:41 am
by Wayne Sheldon
Except for a couple modern cars with weird modern shallow rims very hard to do without a big expensive machine? All my life I have done nearly all my tire work myself both antique and modern. People often ask me why? I tell them that usually, I can do the entire repair myself with my basic tools in less time than it takes to drive them to the tire shop and wait to fill out the repair forms and drive home, then return later to pick them up.
Always wise to not be too dependent upon others anyway!
Posted: Mon Sep 02, 2024 11:45 am
I do a lot of our local clubs' tire mounting - the knees don't appreciate the floor much anymore so I purchased this manual machine for motorcycle tires - works on wires, clinchers & split rims.
Posted: Fri Sep 06, 2024 9:47 am
by AEyssen
A few random progress pictures.
Posted: Fri Sep 06, 2024 10:12 am
by John Codman
Love the speedster - the Stearman 75 ain't exactly chopped liver either!
Posted: Sun Sep 08, 2024 8:14 pm
by AEyssen
Weekend progress pics
Posted: Mon Sep 09, 2024 7:21 pm
by AEyssen
And more pics.
Posted: Sun Nov 03, 2024 11:15 am
by AEyssen
It’s finally a roller. Major components installed. Still planning to “z” the rear frame to align with the drop axle.
Posted: Thu Nov 14, 2024 9:12 pm
by AEyssen
Progress continues. The firewall has since been lowered and moved back and steering column lowered.
Posted: Sun Nov 17, 2024 8:58 am
by AEyssen
Maiden voyage of around 15 miles. Stopped by our local hardware shop where lots of the small hardware pieces were sourced. Then lunch. Ran great.
Posted: Wed Nov 20, 2024 4:51 pm
by AEyssen
Action shot
Posted: Wed Nov 20, 2024 8:29 pm
by A Whiteman
This is great to see! Enjoy!
Thanks for sharing the journey.
Can I suggest this method for cotter pin install:
- 1006184252_cotterpin.jpg (31.06 KiB) Viewed 17590 times
Or the US Military way:
Posted: Sun Dec 29, 2024 9:32 pm
by AEyssen
The summer goal for Luke was to build and drive the speedster to his high school auto club car show this Fall. It’s got about 100 miles on it so far.
Posted: Mon Feb 03, 2025 8:58 pm
by AEyssen
Luke has lots of plans in 2025 for the speedster. One included testing out a “speederator”.
Posted: Mon Feb 03, 2025 10:48 pm
by Chris Paulsen
I like that speederator - it seems so simple. Does it attach to the hand throttle too? Or just foot throttle?
Great to meet you both a couple weeks ago!
Posted: Fri Feb 07, 2025 7:00 pm
by AEyssen
Yes it does connect to the throttle too. It has a slide feature so you can drive with either the peddle or stock throttle (ignore the stacked nuts for spacing
). It also came with tabs that once mounted touch to other peddles and act to disengage foot throttle if you press the other peddles. Luke hasn’t installed those yet. First drive tonight and he said it worked fine.
Posted: Fri Feb 07, 2025 7:02 pm
by AEyssen
Oh and yes great to meet too. We are returning in May for the CARS events. Looking forward to it and saying hello again.
Posted: Thu Apr 03, 2025 9:30 pm
by AEyssen
The speedster has been racking up miles. While interning at a Ford dealership, Luke took the car for show & tell.
Posted: Wed Jun 04, 2025 10:23 pm
by AEyssen
Luke swapped out the Holly carb for this unique Rayfield (Pat. 1911) and intake manifold. We don’t know much about it. The needle tip needed repaired. Lots of adjustment options but it’s running and driving well with it.
Posted: Sun Jul 20, 2025 9:02 pm
by AEyssen
The speedster has been accepted to The Race of the Gentlemen 2025. The race requires a roll bar so Luke, with the help of a great teacher, was able to make a custom roll bar (75% so far) that will be mounted to the frame rails. It will have a couple gussets & braces, then will be fully tig welded.
Posted: Sun Aug 31, 2025 8:10 am
by AEyssen
One month until TROG. At the Winter Clinic, Luke was inspired by the Ford special racer and its headers. So, he designed a manifold plate on the computer, 3D printed it in plastic to confirm fitment, then sent the file to SendCutSend. He TIG welded it (another first) with the help of a mentor. The finished, heat coated headers look and sound great (and spits the occasional flame).
Posted: Sun Aug 31, 2025 8:35 am
by AEyssen
Past couple months the speedster has made several appearances- Prism Motorcycle show, Cars & Coffee meet ups, and a Great Race overnight stop where Luke met longtime Great Racer Curtis Graf.
Posted: Mon Sep 08, 2025 8:21 pm
by AEyssen
Luke decided to make a half hood. Kinda difficult with only a grinder and without an English wheel. But, it is taking shape. Not sure why the pics are rotated.
Posted: Wed Sep 10, 2025 10:04 pm
by AEyssen
One of the many highlights of this build has been the many mentors who have offered Luke advice, parts, time and tricks of the trade. The speedster needed a seat cushion for the metal bomber seat. So Luke sought out help from an upholstery guru, who helped and taught him how to make a padded, vintage looking seat cushion.
Posted: Tue Sep 23, 2025 9:26 pm
by AEyssen
Just a couple weeks before two major T events and Luke started feeling a little clutch slippage. So, he single-handedly pulled the engine, dropped the pan, and removed the hogs head. Pulled the fiber Watts clutch out and installed a metal clutch pack and new, stronger spring. Process required he make a clutch spring tool.
Posted: Tue Sep 23, 2025 9:30 pm
by AEyssen
More pics.
Posted: Sun Sep 28, 2025 5:41 am
by AEyssen
Only 1 week before The Race of Gentlemen and two weeks before the Texas T Party. So, crunch time for all the final preps.
Posted: Sun Sep 28, 2025 6:45 pm
Besides the tension of the straps, I'm hoping there is something on the bottom side of the hood to prevent it from sliding backwards, towards the driver.
Very cool BTW. I'm already jealous of the fun you'll have in the race!
Posted: Sun Sep 28, 2025 6:56 pm
by AEyssen
Yes, great question. Luke welded some angle iron to the underside that rests against the firewall to prevent the hood sliding back.
Posted: Sun Sep 28, 2025 6:59 pm
by AEyssen
TROG assigned Luke car/racer number 66 so it was time to get the livery painted on.
Posted: Wed Oct 08, 2025 1:48 pm
by AEyssen
Well Luke did it. Inspired by videos of prior years events, he set a goal to build a period correct Model T speedster in the manner a teenager would have done in the 20s or 30s. With limited resources and evolving skills, he built himself a car to be proud of and enjoy for years to come. The little #66 did great - he was the youngest driver, oldest car (only T actually) and the slowest. But the car performed great and it turned a lot of heads.
Posted: Wed Oct 08, 2025 2:19 pm
by ewdysar
Well done!
Let Luke know that he is an inspiration to old duffers like myself. I am very impressed with the work that he has done and the dedication that he has shown in working towards his goals. Congratulations to Luke! And congratulations to the family support that has been provided. Good job, Dad!
Keep crankin',
Eric
Posted: Sat Oct 11, 2025 6:49 am
by AEyssen
Less than 48 hours after making the return trip from
New Jersey to home base in the Carolinas, we had to get #66 to Texas for the annual Texas T Party. It would be the first time to show the little car to family and friends who have supported this project. The little speedster was a hit. And Luke set a new top speed much to the dismay of his elders.
Posted: Sat Jan 17, 2026 11:04 am
by AEyssen
The speedster has been getting lots of use. In the process, the radiator leaks have increased. A professional shop attempted repairs (twice) unsuccessfully. So Luke has resorted to chasing the leaks down himself, including taking the entire lower cap off a couple times.
Posted: Sun Jan 18, 2026 5:59 am
by Wayne Sheldon
Done that many times. Being a brass era radiator, is that lower outlet neck cast iron? If so, ancient cast iron is very difficult to solder.
That old cast iron is however, not too bad for brazing. With the cast iron lower outlet removed from the radiator and tank piece, carefully braze all the way around the area where that piece attaches to the brass lower tank piece. If careful, you can repair cracks and severe pitting of the cast iron by brazing. The brass only needs to be thin for solder to stick well, but can be used to fill pits or strengthen weak areas. Once the areas are covered, carefully grind (grinding brass can be dangerous without a special grindstone) the covered areas fairly level, and not too smooth, a little roughness helps solder to grab a stronger hold. Make sure you still have good brass coverage where the piece solders to the brass tank.
Tin with solder both the cast iron piece and the tank where the two pieces are attached.
The cast iron piece and the tank need to be mechanically held together, it was originally done with rivets. I sometimes use about number 8 machine screws. Machine screws can also be used to attach the neck to the tank if you do not remove the tank from the radiator.
Brass instead of cast iron, then tinned, the brass tank, also freshly tinned and held firmly in place by screws or rivets, final soldering of the pieces together is a piece of cake!
I have done that several times.
This can be done on both the lower and upper necks if they are cast iron.
A lot of reproduction brass radiators over the many years also used cast iron inlet and outlet necks.
