What is this?
Posted: Thu Aug 08, 2024 5:09 pm
by Dan Hatch
Is this a Fun Projects mag battery charger? Any one have hook up diagram? Does it have one lead hooks to mag?
Email me at address in pictures if you want to. Thanks Day
- IMG_0260.jpeg (38.12 KiB) Viewed 2844 times
Re: What is this?
Posted: Thu Aug 08, 2024 10:52 pm
by Dan Hatch
Is this bitter engineering battery charger?
Re: What is this?
Posted: Fri Aug 09, 2024 12:14 am
by TRDxB2
Dan Hatch wrote: ↑Thu Aug 08, 2024 5:09 pm
Looks like old Radio Shack parts. Would help to see lettering on components, Also what is the brown tube connected to.
- whatsiisss.png (240.75 KiB) Viewed 2684 times
Fun Projects Mag Charger (just a diode & bulb)
- charger.jpeg (30.96 KiB) Viewed 2684 times
Re: What is this?
Posted: Fri Aug 09, 2024 3:51 am
by Dan Hatch
That is a fuse holder that is part of the turn signals.
I wonder if that circuit board is this?
https://www.snydersantiqueauto.com/cont ... 5165-6.pdf
Re: What is this?
Posted: Fri Aug 09, 2024 10:01 am
by TWrenn
Dan Hatch wrote: ↑Thu Aug 08, 2024 10:52 pm
Definitely not. I had one on my former '11 Torpedo and it looked entirely different.
Re: What is this?
Posted: Fri Aug 09, 2024 10:02 am
by Arbs
Dan,
Can you get a close up with more detail?
Re: What is this?
Posted: Fri Aug 09, 2024 10:16 am
by RajoRacer
Not a Bitner set-up.
Re: What is this?
Posted: Fri Aug 09, 2024 3:34 pm
by Dan Hatch
Try this .Has to be a mag battery charger.
Yellow wire is 12v in
Green is 12v out
Red has no voltage. Must hook to mag.
It is like the Bitter.
Re: What is this?
Posted: Fri Aug 09, 2024 8:50 pm
by JTT3
Dan I believe that’s a Seth Harbuck mag charger. Seth made one very similar to the one pictured. You may recall he was an early proponent (2005) of the ability for the mag to charge the battery. He sent out several to friends including me for a 1915 roadster.
Best John
Re: What is this?
Posted: Fri Aug 09, 2024 8:56 pm
by Dan Hatch
John by chance do you have the instructions for it still? Thanks for the help. Dan
Re: What is this?
Posted: Fri Aug 09, 2024 9:05 pm
by Arbs
The part with the heat sink looks like a voltage regulator. Everything else looks like resistors and one transistor. You may be right, could be a homemade mag charger. These components would be all you would need.
Re: What is this?
Posted: Sat Aug 10, 2024 1:43 am
by TRDxB2
Re: What is this?
Posted: Sat Aug 10, 2024 8:32 am
by varmint
Not and electronics engineer but used to play with this stuff 50 years ago.
This is my guess:
- mag charger.png (272.61 KiB) Viewed 2138 times
Re: What is this?
Posted: Sat Aug 10, 2024 9:02 am
by Dan Hatch
I know what the parts are. I want to know if it is battery charger, which I know it is. And who made it , how it hooks up.
I pulled a big screw up and unhooked it pulling the engine to fix cracked drums. Oh I will remember how that goes, yeah right.
Well with all else going on guess what? I think I have got it right so we shall see.
