Clutch woes
Posted: Thu Aug 08, 2024 5:29 pm
Recently my sister's 1913 touring suffered from "failure to procced" in high gear.
Once I figured out it required more than a simple adjustment, I dug into it to correct the problem.
I pulled this junk out, that someone had installed in place of a perfectly good Ford clutch pack.
The internal driven plates were original Ford.
The external driven plates were made of woven material. The drive dogs were notched into the woven material!
5 of the 6 woven plates had the drive dogs completely worn away & one had a crack!
Makes me wonder about the replacement spring as well.
Genuine Ford parts will be used to put the car back in service.
