Boyco cans for T
Posted: Mon Aug 19, 2024 10:05 pm
by Arbs
Are Boyco cans supposed to hang over the running board this much, or are these for a different vehicle?
Re: Boyco cans for T
Posted: Mon Aug 19, 2024 10:40 pm
by AndyClary
There were different sized cans available. As you suspected, these are appropriate for a larger car.
Doesn’t mean you can’t use them if you want.
Andy
Posted: Mon Aug 19, 2024 11:07 pm
Might be better suited to a 26-7's wider running board.
Posted: Mon Aug 19, 2024 11:58 pm
by Novice
If you can find a mounting tray that's made for them mounting to a narrow running board would not be a problem. mounting tray would still stick out a little but cans would be secure.
Posted: Tue Aug 20, 2024 6:56 am
You can bolt a wooden base to the running board using the existing holes for the fender-to-running board and running board to frame brackets. That way you do not have to drill any holes in Ford parts. The cans can then be mounted to the base board in any way you choose.
Posted: Wed Aug 21, 2024 2:17 pm
The pictured cans are like the ones I bought for $2 and $3 at auction. Yes they were made for cars larger than a Model T, but the price was perfect and they work just fine. I made a carrier that clamps on the running board and doesn't require drilling any holes.
