Rear wheel nut torque
Posted: Tue Jan 15, 2019 11:47 pm
by Oldav8tor
I know that Henry didn't specify a torque value for rear wheel nuts other than "really tight." I've done some research and found 70 ft-lbs, 120 ft-lbs and 200 ft-lbs suggested in early posts. Anyone care to chip in with your recommendation?
Re: Rear wheel nut torque
Posted: Wed Jan 16, 2019 12:31 am
by JP_noonan
Tim, i usually start out at a minimum of 75 lbs, then tighten up to the next nut notch which might end up at 100 lbs.+ or-. Opinions may vary, but 200 lbs. seems very excessive to me.
Posted: Wed Jan 16, 2019 12:46 am
Isn't that one of the places where you're supposed to turn it until just before it breaks? :D
Posted: Wed Jan 16, 2019 3:54 am
by Mindless Automaton
I use 70ft/lb. The reproduction nuts are made of cheese & don't handle much more than 90. Old orig' ones are tougher but mostly all gone. Anything too tough & the axle threads would strip right off so... cheese nuts it is!
Posted: Wed Jan 16, 2019 6:15 am
by JohnH
I presume we're talking about axle nuts, and not the nuts used to secure the rims to wheel. In that case, I start at 110 ft. lbs. and hope a castellation lines up with the hole before I get to 140 ft. lbs. Original and repro nuts and axles seem fine with that. After the car has been driven for a while, I recheck the nut is tight enough - if driven around with it loose, the taper of the axle and hub, as well as the key-way will wear.
I have seen where the axle nuts were done up with an ordinary shifting spanner hand tight; the assumption was the key was all that was necessary to keep everything in position. The result was the most elongated keyway I have seen.
Posted: Wed Jan 16, 2019 9:12 am
by TWrenn
I've had previous cars that I brought home and pulled the wheels for a check-up only to find the rear nuts were barely beyond snug. Thank God for cotter pins! I use a 2' breaker bar on my socket and yank and tug until my back and/or shoulder hurts like heck and the cotter hole is exposed. Havent lost a wheel yet! Just sayin' :D
Posted: Wed Jan 16, 2019 10:29 am
by Scottio
lol. Thats a great one. Tighten it till a shoulder or back goes pop then install the cotter pin. :lol: :lol: :lol:
Posted: Wed Jan 16, 2019 10:57 am
by TFan
I always heard "tighten till failure then 1/4 turn" . Jim
Posted: Wed Jan 16, 2019 11:10 am
by CudaMan
I use JP's method - 70 ft-lbs, then pull more as needed to get the castellations to line up. :)
Posted: Wed Jan 16, 2019 11:03 pm
by Jim, Sr.
Here is the wrench that Ford supplied for the job when our Model T's were new.
This is an original 5Z-248 rear axle Ford wrench. It has a 21 inch long heavy pipe handle.
I have never used it, because i'm afraid I would strip the axle or nut.
Posted: Thu Jan 17, 2019 7:38 am
by mtntee20
So, if my calculations are anywhere near correct, using this wrench, a person would need to push with just over 45 lb. of pressure on the end of the wrench, to get 70 lb/ft of torque on the axle nut. Seems logical. But, if a person really leaned on the wrench, with his body weight, you could get well over 100 lb/ft torque. I'm still confused. I think I will shoot for the 70 - 100 lb/ft zone and to the next castlelation for the cotter pin. Sure don't want that nut loose.
Thanks for the photo. I didn't know Ford had a special wrench for the axle nuts.
