Hood Corners Pads - what are they?
Posted: Thu Jun 13, 2019 5:27 pm
by DHort
4054 and 4054B. I see them in the catalog but have never seen them on a car. Are they rarely used?
Re: Hood Corners Pads - what are they?
Posted: Thu Jun 13, 2019 6:00 pm
by Rich Bingham
Little leather triangular "pockets" meant to be riveted to the inside lower corners of the hood, presumably keep the hood from scratching up the cowl. Unnecessary accessory ?
Posted: Thu Jun 13, 2019 6:07 pm
The late Improved Car used these pads, factory. You can tell if your late T was installed at the factory as you will find tiny hole at the edge of the hood.
Here is original remains of a factory pad. Think these were late 1926 addition, when the Improved Car got the change to Vaproizer carb, and later with the nickel head bolts....all this 'fancy' stuff that Edsel saw done, as he was practicing for the designs of the NEW Ford to come. ;)
Hood Pad.jpg (120.78 KiB) Viewed 7108 times
Posted: Thu Jun 13, 2019 9:42 pm
by Henry K. Lee
Sometimes making your own from scraps of black leather with a simple single stitch is a better alternative. Soak in water for a couple of hours, using a c-clamp with small pieces of wood and wax paper, clamp in place and let sit for a day. Remove and let dry, then reinstall with a little black weatherstripping adhesive. Looks Good!
All the Best,
Hank in Tin-A-See
Posted: Fri Jun 14, 2019 9:00 pm
by blgitn
Very nice!
Posted: Sat Jun 15, 2019 9:34 am
by dunoon
Hank, How did you get that corner pad to mold to the hood?
Rich USN Ret in Va.
Posted: Sat Jun 15, 2019 10:28 am
by dlmyers
They would come in handy to prevent this.
Posted: Sat Jun 15, 2019 5:55 pm
After a Model T got older and was still a good serviceable car items like engine pans, hood pad corners, door straps and a few other items that were considered unnecessary items were discarded. Or at least the remains of T’s that were still fairly complete that I’ve seen over the years. Don’t see many around in this area any more. Maybe frame remains but that’s about it.
Posted: Sat Jun 15, 2019 6:08 pm
by Doug Keppler
Richard, read what he wrote it explains how he had them formed to the hood
Posted: Sat Jun 15, 2019 10:35 pm
by JimKelsey
They are great to have as they keep a klutzy guy, like myself, from scratching the cowl.
Posted: Sat Jun 15, 2019 10:47 pm
by DHort
Doug. The directions make no sense to me either. Soak in water with c clamp, bits of wood, and wax paper. Apply with a little bit of adhesive. I dont see how that would make them look as good as they do. Hank did a great job.
Posted: Sun Jun 16, 2019 7:14 am
by Doug Keppler
Soak in water for about 4 hours clamp them while they're still wet, let them dry in clamped position, remove and use weathestrip adhesive to apply them to the hood
