Looking for a used steering arm for another project. Ball can be worn down a bunch, actually just need the ball its self. Please contact me. Thank you in advance.
Tom
Re: steering arm
Posted: Fri Sep 20, 2024 1:05 am
Tom, if all you need is a ball, the tie rod balls available from the vendors are the same size. I use them to replace the worn balls on early pitman arms.
