recommendation on 6 volt battery purchase
Dave_Kriegel
First Name: David
Last Name: Kriegel
* REQUIRED* Type and Year of Model Ts owned: 1927 1926
MTFCA Number: 52627
Post by Dave_Kriegel » Fri Jun 14, 2019 8:06 pm
It appears the size I need is 19L? but finding one? I will try tractor supply stores tomorrow but any suggestions please I did a battery forum search lots of info on battery carriers and 12 volt but could not find a recommendation on a good 6 volt battery
Ed Baudoux
First Name: Edward
Last Name: Baudoux
* REQUIRED* Type and Year of Model Ts owned: 1927 Fordor 1926 Huckster 1930 Fordor 1930 Tudor
MTFCI Number: 24216
Re: recommendation on 6 volt battery purchase
Post by Ed Baudoux » Fri Jun 14, 2019 8:22 pm
I have had very good results with Napa 6 volt batteries. My last one lasted 12 years.
Grayling Michigan
1927 Fordor
1926 Huckster
Founding member of Northern Michigan Drone Skeet Shooting Club :twisted:
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Fri Jun 14, 2019 8:36 pm
I buy a Group 1 tractor battery at Peavey Mart.
25 roadster john
Last Name: Pawlowski
* REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
MTFCA Number: 49635
Post by 25 roadster john » Fri Jun 14, 2019 9:19 pm
Tractor supply have them in stock. At least at my local store. Remember to check the date of manufacture. Make sure you get the freshest battery.
Post by Norman Kling » Fri Jun 14, 2019 9:34 pm
Some Auto Zone stores carry them. The one here in El Cajon Ca has fresh ones. There should be a sticker on the battery with a date. Try to find one with a recent date. It will last longer. Group 1 6 volts. I have also ordered them from Napa. Those need to be ordered in advance. Takes a day or 2 to receive it at the store. It is the same battery as a standard Model A battery and some of the Chrysler cars in the 30's so not rare.
MTFCA Number: 121
MTFCI Number: 16310
Post by Original Smith » Fri Jun 14, 2019 9:47 pm
I bought one recently at Auto Zone. It would really help if you would tell us what you are using it in!
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri Jun 14, 2019 9:58 pm
I bought my last one about 3-4 years ago from Federated. Deka I believe. Still going strong. :)
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Fri Jun 14, 2019 10:56 pm
Fleet & Farm, TSC, Orscheln — whatever the local farm supply is. Don't let some kid tell you they're only for tractors. :D
Last Name: Hjortnaes
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Sat Jun 15, 2019 12:57 am
I sprung for an optima sealed battery. No extra charging. No hydrogen. No worries.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Sat Jun 15, 2019 1:03 am
I should have asked what year we're discussing. A pre-starter car doesn't require a big expensive battery.
Gonenorth
First Name: Kevin
Last Name: Whelihan
MTFCA Number: 30688
Board Member Since: 2008
Post by Gonenorth » Sat Jun 15, 2019 7:07 am
Looks like a standard tractor battery. I have never gotten any more than three years out of them. Cells seem prone to shorting out. Paid up for a Optima Red Top 6 volt sealed battery. End of issues. And at 850 CCA as opposed to most other farm batteries 600 CCA, it rolls the engine over faster and it starts easier. No leaks either as it is sealed.
KirkieP
First Name: Kirk
Last Name: Peterson
* REQUIRED* Type and Year of Model Ts owned: 27 Touring 24 Coupe
MTFCA Number: 345
MTFCI Number: 141
Post by KirkieP » Sat Jun 15, 2019 7:48 am
I purchased my last one at Big R. I started using a battery maintainer. It appears that has increased its life span for me.
Kirk Peterson
Santa Fe NM
Last Name: Kuehn
MTFCA Number: 28924
Post by John kuehn » Sat Jun 15, 2019 9:03 am
If your looking for a T 6v battery buy a 6v group 1 battery. Common in older tractors, old cars and Model T’s. Get one at Auto-Zone, farm supply stores such as Tractor Supply and other related stores.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sat Jun 15, 2019 10:02 am
His profile says he has a '21..
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Sat Jun 15, 2019 10:33 am
I have usually gotten 10 years use. Typically have to add some DISTILLED water after a few years use
On my 13 I have a Seadoo battery tucked in by the end of the gas tank. I charge it off the magneto. I am running a Tru-fire in a Heinz box
Dave_Kriegel
First Name: David
Last Name: Kriegel
MTFCA Number: 52627
Post by Dave_Kriegel » Sat Jun 15, 2019 11:35 am
Thank you all for the great advice especially on group one size This is for a 1925 starter car I am repairing for a friend
Post by TRDxB2 » Sun Jun 16, 2019 12:01 am
I started a response earlier and saved the draft - but looks like I need to start over
Eckler's used to sell a repro 6 volt FORD battery whose dimensions were 9-1/4" long x 7-3/8" wide x 9" high. Height is measured to Top of posts & 550 cold cranking amps. I some further searching and found that the BCI (Battery Council International) Group Size is 1. This battery size will best fit the physical dimensions, terminal locations and type required for your vehicle. A 19L may be too big to fit in the space available. Check it out
There are many 6 volt batteries available and group sizes, but the first thing to determine is what physical size do you need. While cold crank power is important another factor is charging. There are 6 volt "golf cart" batteries that are designed to withstand deep recharging. I came across some explanation of the common types available. AGM stands out as it is more resistant to vibrations and may be a good choice if you have a voltage regulator.
Flooded lead acid batteries are the most common type of battery you’ll find on the market. They’re versatile in terms of design and use. They come in a number of sizes and aren’t sealed. This means that you can replenish any lost electrolyte. These batteries have lead plates based on sulphuric acid.
Gel lead acid batteries utilize a thickening agent to keep the electrolyte still. It can’t move freely. This is great if you ride rough. If your battery gets cracked, it’ll still run smoothly. The one downside is that it’s completely sealed.
AGM lead acid batteries are relatively new. These batteries use a fiberglass separator to keep the electrolyte in place. AGM batteries are considered to be one of the most robust battery options because they’re spill-proof, resistant to vibrations, and hold up well to impacts.
Post by TRDxB2 » Sun Jun 16, 2019 12:18 am
Just one more thing -- Blain's Farm & Fleet $59.99 after $10 exchange Dimensions:9" X 6-7/8" X 8-3/4" Group Size: 1 Power: 640 CCA
