AC Brake Lining Clean Up
Posted: Sun Oct 13, 2024 10:57 am
by dr1960
My new AC brakes were apparently dragging a bit on the passenger side and after a long drive i discovered that it had heated the hub enough that the seal failed and i had bearing and axle grease all inside the hub. It migrated outside enough that the AC brake lining is also contaminated. I tried cleaning it up carefully with brake cleaner and also doing a bit of sanding but it is still not good. Any suggestions? Do i have to have them re-lined?
Thanks in advance.
Re: AC Brake Lining Clean Up
Posted: Sun Oct 13, 2024 11:36 am
by Farmer J
Take a propane torch and wave the flame over the lining until the grease pops out. Then take either a rag or a wire brush and wipe the grease off. Continue doing this until no more grease pops up. Do not let the flame linger in anyone spot on the brake linings.
Posted: Sun Oct 13, 2024 11:57 am
by DHort
Jerry
Would it be possible to get a big soup bowl and boil the grease out? That blue with white speckles bowl your wife has in the basement and never uses.
Posted: Sun Oct 13, 2024 12:09 pm
by Farmer J
The big bowl I could probably get away with using, but she won’t let me near her stove after I used the oven to help fast dry some painted bolts.
Posted: Sun Oct 13, 2024 12:21 pm
I have filled a steel oil drain pan with gasoline, covered & let soak overnight. Wire brush the lining & wash in the gas the next day.
Gas has turned black from the old leached out grease. Dump out the fuel & repeat another night or 2 until the remnant fuel is clean the following day.
Posted: Sun Oct 13, 2024 2:15 pm
by RVA23T
But she will let you use the gas grill RIGHT???
Works almost the same a a gas oven and stove if you have a side burner.
Warms up ring gears to easily go onto the carrier!
Posted: Sun Oct 13, 2024 6:25 pm
by RecklessKelly
I used paint thinner to clean mine. Scrubbed with a paint brush. Followed up with brake cleaner spray. Hung to dry in the sun. Quick and easy and my brakes work great now.
Posted: Mon Oct 14, 2024 12:53 am
by DHort
I know John states he uses gas, but I would be afraid of a fire. I use kerosene. Works great. Put on a pair of latex gloves as well.
Posted: Mon Oct 14, 2024 1:24 am
by Dan Hatch
Back in the day when all we had were drum brakes and this happened it was death sentence for shoes. There was no cleaning them . Only replacement.
Posted: Mon Oct 14, 2024 3:16 am
by Craig Leach
I'm with Dan,
I know of no MFG. that recommends any procedure for cleaning oil contaminated linings. I have cleaned lightly contaminated woven linings
with lots of chlorinated brake clean, soak, dry, soak, dry again until they look new. If they don't look like new discard & replace. It comes down
to how much do you like those in your car with you if the brakes fail. & how good is your insurance if you hurt someone because you saved some
money? Two wheel brakes are sketchy @ best lets not take chances to save a few dollars. Please.
Craig.
