Starter Motor Amperage
Posted: Thu Oct 17, 2024 6:29 pm
This one should be an easy one. I have found documentation on a Model T starter motor, stating the amperage to be 160 amps during use. I am planning to add a starter solenoid and want to ensure I purchase one with an appropriate amperage rating.
I would like to know if the 160 amp rating is correct? I would also like to know what amp rating solenoids are currently being used successfully. I am looking at a 200 amp 6 volt solenoid.
Thank You all for reading this and especially those answering this old man's questions.
Good Luck to you ALL.
Terry
Terry
