APCO Tie Rod end lube
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Sun Jun 16, 2019 2:28 pm
Looking at an APCO adjustable tie rod end, it appears there is room to install a zerk fitting. I know it isn't original but has anyone ever done it and if so, did it help?
1952 Willys M38a1 Jeep
Dropacent
Last Name: Morsher
Re: APCO Tie Rod end lube
Post by Dropacent » Sun Jun 16, 2019 2:33 pm
Yup and yup. Please don’t tell larry smith. I have an original with a pin alemite fitting, so they were sold like that, so that would be more appropriate.
Last Name: Juhl
MTFCA Number: 50297
MTFCI Number: 24810
Post by Oldav8tor » Mon Jun 17, 2019 9:23 pm
Just a comment - The APCO adjustable tie rod ends seem to work much better than the fixed cap. They compensates for any irregularities in the ball and result in very smooth action with no binding or loose spots. Since my car will be a driver I am going to install zerks to make greasing easier.
dunoon
Last Name: Davis
Post by dunoon » Mon Jun 17, 2019 9:40 pm
Good idea, I'll look into doing that before I install them.
Last Name: VanOoteghem
Post by Jerry VanOoteghem » Mon Jun 17, 2019 9:46 pm
Be sure the zerk doesn't extend too far into the housing such that it interferes with the spring. Other than that, looks like a good enough idea.
fbergski
First Name: Philip
Last Name: Berg
Post by fbergski » Tue Jun 18, 2019 8:04 am
My 11 touring that I got from my g'pa had APCO's already installed with grease fittings. Not sure if he did it (highly unlikely) but the front end is still tight after fifty years of service. I normally give a shot of grease every few months.
