Neoprene rear axle seal installation
Posted: Mon Nov 04, 2024 10:05 am
by johnr
I am rebuilding my rear axle of which I am installing new bearings and seals.
I found out that the seal outside diamater is larger than the inside diamater of the outer race requiring
the seal inserted prior to the outer race.
Should I assemble the axle and differential into the housing first.
Next install the seal with metal plate facing outward and then follow up with installing
the outer race.
If I go this route I will machine a pusher up to insert the seal to the bottom of the axle
tube.
Sound about the right way to proceed ?
Re: Neoprene rear axle seal installation
Posted: Mon Nov 04, 2024 10:10 am
Yes. You have the process correct. Have used the sleeve puller to place the neoprene seal, just push it in with the outer non button end of the puller. Pre-grease the neoprene seal so it slips on the axle easy.
Then place a radiator gear drive hose clamp around the sleeve to collapse it some for slipping it in , align the bump on the sleeve to the recess in the housing
Posted: Mon Nov 04, 2024 10:47 am
Sometimes the sleeve will not fit all the way in. Check that the bearing will go in all the way and then cut off a small amount of the inside edge of the sleeve till it will slip in to where the dimple fits the hole and the hole mates with the grease cup.
Posted: Mon Nov 04, 2024 11:50 am
This is long, but it includes installing the new seals:
https://www.youtube.com/watch?v=AfxWPsF4KhQ
Posted: Mon Nov 04, 2024 12:25 pm
by johnr
Thank you for the help.
Posted: Tue Nov 05, 2024 7:35 am
by John.Zibell
A piece of appropriately sized PVC pipe is excellent for setting the inner seal. A bit of black RTV on the side that hits the inner axle housing makes for a good seal.
Posted: Thu Nov 21, 2024 11:04 am
by Daktarirp
Is there a part number for just the neoprene seal that is fitted to the modern aluminum housing? I have a pair of housings that are intact, but the seals are damaged. Just being cheap, and trying to recycle the housings with new neoprene.
Posted: Thu Nov 21, 2024 2:33 pm
by SurfCityGene
Rich, YES, you can order new seals from the mfg by size. try search CRC or National seals. Look carefully at the old seal and it may have a part number.
Posted: Thu Nov 21, 2024 4:24 pm
by Daktarirp
Thanks, Gene. I have the rear axle apart at a friend's shop, unfortunately not nearby. I suspected someone has been down this road before and might have a handy dandy part number. Failing that, I will chase the rabbit a bit on my own and post a number if I am successful. I really do appreciate your response. I see you have a '12 Torpedo. My long-legged self loves the extra leg room (I have an '11. It is a sweet runner.
RP
Posted: Thu Nov 21, 2024 7:11 pm
by michaelb2296
OPR 09-27 Neoprene Rear Axle Inner Seals/ Pair/modern
Item #: EK-16-53999-1
Unit Price: $2.99
QTY: 2
Ecklers…. You get two for $3
Posted: Wed Sep 24, 2025 10:02 am
by jwipprecht
The YouTube video above illustrates reassembly. It is fantastic.
Posted: Wed Sep 24, 2025 3:34 pm
by DHort
Those Eckler seals are $11.99 on the Eckler website, but I am not sure that is what he is looking for.
Daktarirp
Are you looking to replace the seals on this housing?
- 101s.jpg (2.68 KiB) Viewed 1129 times
Posted: Wed Sep 24, 2025 5:25 pm
by ewdysar
DHort wrote: ↑Wed Sep 24, 2025 3:34 pm
Daktarirp
Dave,
This conversation ended almost a year ago, until it was resurrected with a random comment. Hopefully Daktarirp figured out his solution back in 2024.
Keep crankin',
Eric
Posted: Thu Sep 25, 2025 11:38 am
by DHort
I see.
2 posts about the same thing at the same time.
I am so confused. Both are old postings..
Posted: Thu Sep 25, 2025 11:47 am
DHort wrote: ↑Thu Sep 25, 2025 11:38 am
I see.
Still, good advice, nonetheless!
