Physics Rules!
Posted: Thu Nov 07, 2024 10:03 am
Hi all,
I've been having trouble with a weeping sediment bowl on my 25. I found another bowl that is rusty and locked up. I tried heating and using PB plaster to break parts free.... and maybe a little too much force. At one point I stopped and read one of the postings here about heating the bowl and putting it in the freezer. Why not try that? The concept is that different metals heat and cool at different temperatures. So I tried it. Put the heated and smoking (propane torch) sediment bowl in the freezer using welding gloves and immediately thought: What if that smoke would ruin the other foods in the freezer. Well it didn't. After the bowl cooled I put it in my vise and tapped it with a hammer and it came off. Wow. Then I did the same thing with the valve and same results. Off it came. Of course, I had tried hammering the valve and mushroomed the end a little; but I can fix that with no problem. The different metals separated when they cooled and broke free. Physics!
John
John
