Interesting tinny sound at startup
Topic author - Posts: 1011
- Last Name: Osterman
On the last few cold starts I’ve heard a strange metallic tinny sound that eventually goes away in about two or three minutes. Always thinking the worst I thought it was something loose in the transmission imagining some piece that fell off and is kicking around in there. I lubricated the fan thinking this might be the problem; nope. I changed the oil thinking I might find something in the oil ... nope.
Then the next time it happened I thought it came from underneath so I quickly climbed under and it sounded strong around the muffler and pipe assembly. I thought that maybe when I changed the manifold gaskets recently I may have put the exhaust pipe back in a way that caused a rattle. So, I loosened up the pack nut and tightened it while wiggling the pipe to seat it. It still didn’t make much difference. So, I’m still wondering what’s making the sound ... but at least it goes away once the engine’s hot. Could be because I’m using a cast iron end muffler and the pipe is simply pushed into the inlet hole. It’s probably something really simple like once the pipe gets hot it fits differently. I was once told that when you hear hoof steps behind you ... think horse ... not zebra. I’ll figure it out.
- MTFCA Number: 1219
Re: Interesting tinny sound at startup
The carburetor heat pipe has fooled me before. You might check where it is bolted to the manifold clamp. You may recall I pulled the oil pan inspection cover looking for a rattle before I discovered the former.
I’m not using a heat pipe on my carburetor.
Exhaust leak? As the engine warms up and metals expand the leak seals. Just a thought.
- First Name: Kevin
- Last Name: Matthiesen
- * REQUIRED* Type and Year of Model Ts owned: 1926 Coupe, 1921 speedster, 1925 TT, 1916 Exp
- MTFCA Number: 11598
This is another long shot, but because your car was fine before the U and J carburetor change, try checking the rod from the bell crank to the carb. It is at a different angle now and may need some tightening at the carb or bell crank. When car is warm it is in a different position, so no noise.
- First Name: Harold
- Last Name: Schwendeman
Make sure the bendix cover is not coming loose! (....altho' that should also cause an oil leak,..???)
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
- MTFCA Number: 28114
- MTFCI Number: 21834
I had a crankshaft pulley that was loose and made a noise that took awhile to find.
- First Name: Rich
- Last Name: Bingham
I've found through the past two years, my Model T runs better and quieter than ever. Meanwhile, the audiologist claims I have increased hearing loss. I refuse to believe there's any connection hear (!) Bad noises get worse and louder . . . inconsequential noises that go away, well, What ?? Me worry ??
"Get a horse !"
- First Name: David
- Last Name: Wilson
- * REQUIRED* Type and Year of Model Ts owned: 1927 Canadian Touring
- MTFCA Number: 51596
Loose through bolt allowing baffles to rattle?
Well ... not the throttle rod, crank pulley, fan pulley, bendix cover. The rod running through the muffler sounds plausible.
Have to do a dry plate photography shooting workshop in Letchworth Park (Grand Canyon of the East) starting tomorrow. So I’ll keep thinking about it while I’m out of contact with the civilized world and work on it this coming weekend when I get back.
- Last Name: Hanlon
- MTFCA Number: 50191
Can you tell if it's front or rear or middle ?
Your eat on a long screwdriver handle works like a stethoscope, you can move it around and see if you can pick up the area.
Could be a "loose nut behind the wheel" !
