Interesting tinny sound at startup
Posted: Sun Jun 16, 2019 10:12 pm
On the last few cold starts I’ve heard a strange metallic tinny sound that eventually goes away in about two or three minutes. Always thinking the worst I thought it was something loose in the transmission imagining some piece that fell off and is kicking around in there. I lubricated the fan thinking this might be the problem; nope. I changed the oil thinking I might find something in the oil ... nope.
Then the next time it happened I thought it came from underneath so I quickly climbed under and it sounded strong around the muffler and pipe assembly. I thought that maybe when I changed the manifold gaskets recently I may have put the exhaust pipe back in a way that caused a rattle. So, I loosened up the pack nut and tightened it while wiggling the pipe to seat it. It still didn’t make much difference. So, I’m still wondering what’s making the sound ... but at least it goes away once the engine’s hot. Could be because I’m using a cast iron end muffler and the pipe is simply pushed into the inlet hole. It’s probably something really simple like once the pipe gets hot it fits differently. I was once told that when you hear hoof steps behind you ... think horse ... not zebra. I’ll figure it out.
