Fun projects hood shelf springs- who carries now?
Posted: Fri Nov 08, 2024 5:00 pm
by Bmettli
Hi all,
Funprojects used to carry CORRECT hood springs but since they are gone, I did not see them on birdhaven or others. Or has anybody found a part substitute readily available to order that works better than the standard supplier ones? Thanks
Re: Fun projects hood shelf springs- who carries now?
Posted: Fri Nov 08, 2024 5:48 pm
by Will_Vanderburg
The only way to know if they have them is to call them. Their catalog, which I have, does not identify products that were formerly made by others
Posted: Sat Nov 09, 2024 12:53 am
My 14 year old son made a compressor to fit the ridiculously stiff springs offered by the vendors at the time. These put way too much load on an aluminium hood, so I replaced them with much lighter gauge ones from a hardware shop assortment. They are still in use after decades.
Posted: Sat Nov 09, 2024 9:12 am
by CudaMan
I second Allan's recommendation. The stock hood hold down springs on my 1912 Flanders were even stiffer than the Model T springs, so I replaced them with some weaker springs from the hardware store, they work great.
Posted: Sun Nov 10, 2024 5:26 pm
by Bmettli
Yes, I got replacement 2 inch spring from Menards today for around $1 each. Much better
