Cast iron warford install problem
Posted: Tue Nov 26, 2024 12:32 pm
I have tried searching for my particular problem with the installation of a 920-1 case iron case Warford in a 1914 Touring. Problem is - the center "U" shaped portion of the emergency brake shaft hits the front of the Warford preventing the Ford transmission from going into high gear. Has anyone experienced this problem and how did you fix it? TIA Jerry
