Removing engine with a Warford question
Posted: Wed Nov 27, 2024 5:34 pm
by Jim11787
My first time pulling a model T engine. It’s a 26 Roadster Pickup with an older aluminum Warford installed. I do have a frame brace supporting the Warford. Question-do I unbolt the Warford from the hogs head when hoisting the engine out (my preference) or do you try to take the Warford out bolted on which seems like it would be difficult? Also if leaving it in place does the Warford need to be drained before unbolting from the hogs head?
Re: Removing engine with a Warford question
Posted: Wed Nov 27, 2024 6:00 pm
by George House
Unbolt it from the T transmission. Leave it hanging on its support. Won’t need to drain it..
Posted: Wed Nov 27, 2024 7:25 pm
by mtntee20
Jim,
I agree with George, leave it in place. You might want to support the front of the Warford a bit, just to prevent bending the support bracket and putting stress on the drive line tube.
Good Luck.
Posted: Thu Nov 28, 2024 8:48 am
by John.Zibell
What Terry and Jim said is how I do mine. Remove from transmission but support the Warford.
Posted: Thu Nov 28, 2024 10:06 am
by Jim11787
Thanks for the info guys!
