Snowmobile ski question
Posted: Sun Dec 15, 2024 9:39 pm
by Dennis Prince
I am building skis for a snowmobile build and I am wondering do the original skis have a skeg down the middle of the bottom? And can I get width and lengh measurements. Thanks, Dennis
Re: Snowmobile ski question
Posted: Mon Dec 16, 2024 11:01 am
by myersair
Yes they do. I have a set and they are about 3/4 wide.
Posted: Mon Dec 16, 2024 3:05 pm
by Dennis Prince
Randy, Thanks for the answer on the skis, does the skeg run the entire length of the ski? Dennis
Posted: Tue Dec 17, 2024 12:22 am
by Joe Reid
Here are the skegs on an ARPS Supersnowbird ski.
Posted: Tue Dec 17, 2024 6:24 pm
by Dennis Prince
Thank you Joe for the picture that answers that question. Dennis
Posted: Tue Dec 17, 2024 8:08 pm
by KBurket
Here’s an old post with a drawing with dimensions.
http://www.mtfca.com/discus/messages/59 ... 1480825339
Keep us posted on how your skis turn out.
Posted: Tue Dec 17, 2024 11:58 pm
by Dennis Prince
Thanks for the links, I will let you know what I end up with. Dennis
Posted: Thu Dec 26, 2024 3:36 pm
by Dennis Prince
I finally got my skis finished. They are made out of things out of my raw materials pile (formerly known as a scrap pile) I used wheels that were no good for tires, some broken Model A springs, old bed frames, chain links off a potato digger and what was part of the kitchen remodel at the Elk's Lodge 25 years ago. The skeg on the under side I made 14 inches long and now all I need is snow to test them out. As you can see from the pictures it is not a traditional T snowmobile, my nephew had these tracks for his side by side and doesn't like them so a friend and I put 2 tracks a piece on our T's. We will see how well they work. The only time in my life that I have ever wanted it to snow.
Posted: Fri Dec 27, 2024 12:23 am
by Joe Reid
Dennis that turned out really nice. Take some shots out in the snow. Model T’s are light but I wonder about boyancy on top of the snow. This is the 30’s version by ARPS.
Posted: Fri Dec 27, 2024 9:41 am
by Mark Nunn
Dennis, I'm preparing to make a wood rim for my steeringwheel. I never considered making one like yours. I like it, but I think that I'll stay with the factory shape.
Posted: Fri Dec 27, 2024 10:17 am
by RajoRacer
Rather peculiar use for a rare 1925 steel p/u box.
Posted: Fri Dec 27, 2024 1:25 pm
by Mark Gregush
Posted: Fri Dec 27, 2024 1:42 pm
by Fordwright
Dennis Prince wrote: ↑Sun Dec 15, 2024 9:39 pm
Nowadays, some snowmobile skis have a tungsten carbide rib going down the middle. Expensive, but they don't wear down like regular steel, even the hardened kind.
Posted: Sun Dec 29, 2024 12:24 am
by Joe Reid
This is how my Supersnowbird started out. The cab metal is pitted more on the inside than outside. The Model A frame was cut, bent and welded to make it straight for some reason and it came with the 25 T pickup box. The frame cross members are now oak and fiberglassed. That is the reason it has the 25T box.
Posted: Sun Dec 29, 2024 12:41 am
by Joe Reid
Supersnowbird frame. It is bent parallel behind where the cab sits. ?????? You work with what you got.
Posted: Sun Dec 29, 2024 12:53 am
by Joe Reid
The box required a lot of hammering and reshaping.
Posted: Sun Dec 29, 2024 10:42 am
by Dennis Prince
Joe, You did a really nice job on your Supersnowbird. With it having no rear fenders I thing that the 25 bed looks better than a Model A bed would, looks like a fun vehicle. Do you have to get in and out of the window with that track setup? I am just waiting for snow, all of my snow is coming pre melted.
Posted: Sun Dec 29, 2024 11:50 am
by RajoRacer
Thanks for the tutorial & explanation, Joe !
Posted: Sun Dec 29, 2024 12:56 pm
by Joe Reid
The doors are cut and remanufactured to open over the tracks. Still not too easy to get in.
