23 speedometer cable
Posted: Tue Dec 31, 2024 11:42 am
by big2bird
What is the correct length for a 23 touring?
What was the original finish on it?
Re: 23 speedometer cable
Posted: Tue Dec 31, 2024 12:31 pm
by Russ_Furstnow
If you have a Stewart speedometer and the swivel is placed ahead of the axle, the length is 60", and the finish is black. I hope this helps, Russ Furstnow
Posted: Tue Dec 31, 2024 12:43 pm
by big2bird
Yes, it does. Thank you.
Posted: Tue Dec 31, 2024 12:50 pm
by big2bird
I have a 60" and a 66". 60" will go on the car.
What would the 66 be for? Just curious.
Posted: Tue Dec 31, 2024 1:05 pm
by RVA23T
Back/Mother-in-law seat driver speedo placement ;)
Posted: Tue Dec 31, 2024 9:51 pm
The longer cable may be called for if the speedo drive is mounted on the other side of the car to the speedo. This is sometimes necessary if the swivel joint runs in the opposite direction to normal for a T. Swivels can be LH or RH rotation.
