14 Runabout progress
Posted: Tue Jan 14, 2025 7:52 pm
by Art Ebeling
The bodywork on my 14 Runabout is almost finished and shoulld be ready to paint in the next couple of weeks. The body had a nasty patch on the back coverering a big rust hole and several subpar patches along the bottom under the door and on the driver side.
Re: 14 Runabout progress
Posted: Tue Jan 14, 2025 8:34 pm
by KWTownsend
Looking good!
Black primer?
Posted: Tue Jan 14, 2025 9:07 pm
by Art Ebeling
Keith, Yes on the black primer as the car will be dark blue. I can't decide between your DB332 OR Russ's DB904. I want it to look like this picture. I think it may be closer to the DB904? Art
Posted: Wed Jan 15, 2025 6:21 am
by George House
I zoomed in to see a really nice professional grade repair in that bottom rear panel. Good job Art.
Coming along nicely !!
Posted: Wed Jan 15, 2025 6:55 am
by Art Ebeling
Thanks George, Here are pictures of the "before". Art
Posted: Sun Feb 02, 2025 8:09 pm
by Art Ebeling
Here is a picture of the painted turtle deck. Art
Posted: Fri Feb 07, 2025 6:15 pm
by Art Ebeling
Here are some pictures of the painted body using the DB904 color. Art
Posted: Fri Feb 07, 2025 8:02 pm
by Dollisdad
Looks good and I like the blue color.
Posted: Sat Feb 08, 2025 11:24 am
by pkhammer
Art, very happy to see the amazing progress on this Roadster! I'm convinced it went to the right home! Great work!
Posted: Sat Feb 08, 2025 11:37 am
by Norman Kling
It looks very good! You really know how to do a good repair and paint job. And you have an original body, not a reproduction! I restored one Model A many years ago. Then I did two Model T's. One thing I learned the hard way is not to take shortcuts. At first I thought that the finish coat would fill in the imperfections in the preparation. That was a big mistake. I also shimmed up the body from the bent chassis. Also a big mistake. I found that the car pulls to one side and I have to steer to one side just to keep straight on the road! Next one I did I checked out the chassis and got it straight first. Then I worked on the body. I got the filler as completely smooth as I could then put on primer and got it smooth first before putting on the finish coat. Came out much better. And the car runs straight on a flat road! Your car looks beautiful. :D
Posted: Sat Aug 16, 2025 6:59 pm
by Art Ebeling
I have been dry fitting the fenders and running boards. I also started on the upholstery. Art
Posted: Sat Aug 16, 2025 9:04 pm
by George House
Don’t forget - like I did - to cherry stain the firewall :o(
Posted: Sat Aug 16, 2025 9:18 pm
by Art Ebeling
I got that!
