Ford use of cotter pin fasteners
Posted: Mon Jan 20, 2025 6:17 pm
by 49willard
I am currently painting the chassis on my 1912 Foredoor. The chassis fasteners have cotter pinned nuts. I assume that this was done due to the poor and lumpy roads of the time. Did Ford stay with this practice all the way through Model T production? Having restored an A many years ago I do not remember there being so numerous cotter pinned fasteners. What is the history?
Re: Ford use of cotter pin fasteners
Posted: Mon Jan 20, 2025 7:28 pm
by Mike Silbert
Ford used cotter pins heavily through 1926.
For the 1927 model year cotter pins were being replaced with lock washers.
Exact transition dates are nominal just like everything Ford.
Critical fasteners stayed with them through the end and beyond.
I assume it was a cost cutting measure since a lock washer is faster, cheaper, easier to install then a cotter pin.
Nothing is more secure than a cotter pin or safety wire, except maybe 100 years of rust.
Posted: Tue Jan 21, 2025 7:21 am
by Humblej
My unrestored 23 T has cotter pins made with equal length legs which would make installation more difficult. The assembly line solution in 1923 appears to be to not separate the legs but push them over as if a single pin. The cotter pin shown in the picture is on the right spindle arm. All the cotter pins I can see have been installed this way.
Posted: Tue Jan 21, 2025 8:13 am
by RecklessKelly
That cotter pin looks a little new- electroplated, it could have been replaced and the guy did a cheese job on it. The original ones I find on mine have a dull look to them.
I can never find the exact pin in the hardware store, they are either too small and head could almost go thru the pin hole or I can barely push the next size up into the hole. Could be that they arent made to the old sizing standard or not sold in size incerments that fit the T. They dont have the offset end like they used to. I usually cut down one end if its possible with my snips.
Posted: Tue Jan 21, 2025 9:08 am
by Humblej
John,
The cotter pin shown in the picture, as well as all the others on my car, are unplated, unpainted, even leged pins that have been in the car for 100 years.
Posted: Tue Jan 21, 2025 9:24 am
by Mike Silbert
Here is an article written back in the day describing the 6 sizes of the 95 cotter pins and where they go.
They are 3 different diameters and available from many places.
I usually get a assortment kit and loose most of them when the case pops open
I would give credit if I knew who originally wrote it.
Posted: Tue Jan 21, 2025 9:51 am
by RecklessKelly
Maybe the shine of the flash made it look newish.
Posted: Tue Jan 21, 2025 1:27 pm
by Drobnock
Of course, the use of baling wire and small finishing nails work too.
Posted: Tue Jan 21, 2025 3:47 pm
by RecklessKelly
Sure, whatever you can find in the barn.
Posted: Tue Jan 21, 2025 4:06 pm
by Steve Jelf
Elizabeth's Hairpins
is from Murray Fahnestock. If remember correctly it's pretty accurate, with one or two minor errors.
Posted: Wed Jan 22, 2025 10:26 am
by John Codman
I wasn't dressed to crawl under my '27, but it uses cotter pins on the spring shackles and on the bottom steering column support. The weather is crappy outside today, so maybe I will find the time to get under it and see if there are others.
Posted: Wed Jan 22, 2025 12:56 pm
by Oldav8tor
Fasteners will loosen on anything that moves. There isn't a single structural fastener on an airplane that doesn't have a self-locking nut, cotter pin or safety wire securing it. Henry used what was available and cheap back in the day.
Posted: Wed Jan 22, 2025 1:12 pm
by DanTreace
49willard wrote: ↑Mon Jan 20, 2025 6:17 pm
Here is some of the history, excerpt from a letter to Mr Henry Ford, from a F.H.Briggs, dated Sept 19, 1906. Mr Briggs wrote about some quality issues of his new Ford Model N. One can assume that Henry read this letter, and found ways to fix loose fasteners.....Cotter Pins!
Posted: Wed Jan 22, 2025 3:54 pm
by J1MGOLDEN
My uncle was born about 1900 and has his first car, and that was a Ford about 1920.
He bought a new Ford in 1950, and the first thing he did was jack it up, and spend about half a day tightening or try to tighten every nut or bolt he could find.
He seemed a little off his good sense at the time, but now I know why he did it.
He also got his first truck driver's license about 1915 in New York City.
Not long after that, he got his first speeding ticket with that truck for doing 18 MPH in a 14 MPH truck loading area.
What really made him mad was the police officer caught him while riding a bicycle and he did not think the speedometer was that accurate on a bike.
The $8.00 ticket had to be paid by him, and that was almost a full week's pay then.
Posted: Sun Jan 26, 2025 8:52 am
by Mark Gregush
Bet you are talking about all the cotter pins in the bolts holding the pan to block/hogs head?
None of the cars I work on are points cars, so those locations get lock washers which is what Ford went to later. Besides, I have yet to assemble those parts and have not needed to come back later and give a little snug down after the car had been driven a while.
Posted: Mon Jan 27, 2025 1:12 pm
by Original Smith
Don't forget the special cotter pins designed to fit the top irons in 1921-22.
