What is this ford wrench for?
Clockdoc
Last Name: Grabowski
MTFCA Number: 50154
Post by Clockdoc » Fri Jun 21, 2019 5:23 pm
I’m wondering what this ford wrench is for? Has Ford script with U.S.A. on one side and the letter M on the other.
Last Name: Seth
Re: What is this ford wrench for?
Post by perry kete » Fri Jun 21, 2019 6:34 pm
OK, Everyone knows that I'm the forums resident smart a$$ so I'll answer...
"What is this wrench used for?"
It's used to tighten Nuts on bolts! :roll: :roll: :roll:
Tractordoc
Last Name: Barclay
Post by Tractordoc » Fri Jun 21, 2019 7:47 pm
Sorry I can't help it. If you turn it around you can use it to loosen bolts and nuts also.
Last Name: Gregush
Post by Mark Gregush » Fri Jun 21, 2019 8:19 pm
It would be Ford Model A up including tractors. Not T and not band adjusting wrench. The openings are ether 1/2-9/16 or 9/16-5/8.
1920 Dodge touring
Clockdoc
MTFCA Number: 50154
Post by Clockdoc » Sat Jun 22, 2019 10:03 am
Thank you Mark, much appreciated.
