Rear fender brackets on a 26 roadster
Posted: Mon Feb 10, 2025 6:11 pm
Should one put a washer BETWEEN the bottom (forward) hole of the rear bracket and the frame to make up for the thickness of the fender? The top (rear) hole goes thru the bracket and the fender. Or is the thickness of the fender so negligible that the bracket will just bend enough to pull it up against the frame anyway?
