Ranch Doodlebug Build
Posted: Fri Feb 28, 2025 3:08 pm
by Mark Chaffin
I thought I would share a couple pics of the Ranch Doodlebug build. Engine and Ruckstell are done. A huge shout out to Mr. Hank Lee for rebuilding my Zenith carburetor as I know it has been done right and also for modifying my Winfield intake manifold to ensure a proper fit. Hank is indeed an artist. Thanks Hank!
Re: Ranch Doodlebug Build
Posted: Sun Mar 02, 2025 12:13 pm
by Charlie_26_TT_Ccab
Looks like itβs coming along nicely since
last months visit. Sounds like you have some more shop space now or will shortly.
Best to you and your family, Charlie
Posted: Mon Mar 03, 2025 10:01 am
by Mark Chaffin
Hi Charlie,
Yes. Moving along at break neck speed as time permits. I was speaking with Hank Lee the other day and mentioned it would be fun making a one off four wheel drive setup to replace the stock front axle. I mentioned a few ideas I had which were simplistic in nature. Boy did I open up a can of worms! Hank was all over it! Like me, Hank loves a challenge and can't sit idle for more than a few minutes. I would not be surprised if Hank didn't already have a few ideas in motion. I've learned I have to be careful what I say or it ends up on my door step! I sure do admire that guy. I can't even come close to his level of talent and we make many parts for beloved Model T. A bromance indeed!
Posted: Mon Mar 03, 2025 10:54 am
by modeltspaz
Mark,
Check out the Livingood 4 W. D. setup for Model T Fords. A few years back, I believe that the original manufacturer's grandson was considering reproducing the set-up.
I believe he built one and installed it in a car. The only big modification needed was that the front spring needed to have a special bend at one end to clear the offset differential housing.
Most of the differential parts were stock Ford, or modified T components. There was a video of a car with a Livingood set-up on YouTube. Not sure if it's still there.
Mike Spaziano.
Posted: Mon Mar 03, 2025 11:56 am
by Mark Chaffin
I'm aware of the Livinggood setup. More complicated than it needs to be. Spring setup and all. It also has a few limitations which can be improved upon. In my humble opinion. Thanks for the info though.
Posted: Wed Mar 12, 2025 7:38 pm
by Mark Chaffin
Frame shortened 12 inches as well as driveshaft.
Posted: Thu Mar 13, 2025 7:14 am
by Aussie16
What head are you running there Mark? It looks pretty chunky?
Posted: Thu Mar 13, 2025 10:16 am
by Mark Chaffin
The head is a cast iron original TURBO. I've only seen one other in my travels.
Posted: Wed Jul 30, 2025 8:22 pm
by Mark Chaffin
by Mark Chaffin
Posted: Wed Jul 30, 2025 9:02 pm
by Ed Fuller
Nice work Mark! I really like the hood you are using.
Posted: Wed Jul 30, 2025 9:13 pm
by big2bird
That will be sweet and fun.
Posted: Thu Jul 31, 2025 6:41 am
by Henry K. Lee
LOOKING GOOD THERE BIG DAWG!
Posted: Fri Aug 08, 2025 12:41 am
by Mark Chaffin
Posted: Fri Aug 08, 2025 12:43 am
by Mark Chaffin
Posted: Sat Aug 23, 2025 9:24 am
by Mark Chaffin
Installing cycle fenders and brackets.
Posted: Sat Aug 23, 2025 12:50 pm
by Bills Auto Works
Hey Mark,
That thing is coming along nicely from when I was there a few months ago! I don't know whether to be happy for you that you are making major progress or sad for myself since I can't seem to make any on my stuff. LOL I guess both!
God Bless
Bill
https://www.jalopyjournal.com/forum/thr ... ed.614419/
Posted: Sat Aug 23, 2025 5:17 pm
by A Whiteman
Thanks for the pictures mark, looking good.
Did you make the cycle guard mounting brackets? They are very neat and I am curious how they fit and how they are braced.
Would you mind sharing a few more details??
Thanks again
Adrian
Posted: Sat Aug 23, 2025 6:01 pm
by Mark Chaffin
Yes. The spindle brackets were made by hand. With two tabs welded on the plate to be mounted using the spindle arm. The spindle arm boss and nut were machined down 1/8" each to allow clearance. The rods are cold role steel threaded 1/2-20 at 4" Length for adjustment. The opposite end was turned down on a lathe to .425 for the fender eyelets. Once the brackets are attached to the spindle, a 1/4-20 short bolt was added front and rear to prevent the bracket from rotating. A few more pictures have been added to illustrate further.
Posted: Sun Aug 24, 2025 3:35 am
by A Whiteman
Thank you, that is a clever solution! I will salt that idea away
Cheers
Adrian
Posted: Sun Aug 24, 2025 11:50 am
by Mark Chaffin
Thanks Bill! For those in need of transportation, Bill is a true professional.
Posted: Sun Aug 24, 2025 12:15 pm
by skyhunter
Nice! In New England they got a totally different idea of what a T doodlebug is, that would be a complete car here.
Posted: Sun Aug 24, 2025 4:09 pm
by Mark Chaffin
I guess it pretty much is a complete car. Just 12" shorter. Since we're located in California, I can safely say, it identifies as a Doodlebug. Pronouns are Putt and Putt.
Posted: Sun Aug 24, 2025 5:08 pm
by big2bird
Your going to beat me to paint Mark.
I'm still fixing errors from years ago, but I will finish this car.
Posted: Sun Aug 24, 2025 8:20 pm
by Mark Chaffin
Still another month or so from paint. I did already purchase the John Deere green paint though.
Posted: Sun Aug 24, 2025 10:26 pm
by big2bird
Explains the yeller wheels.
Posted: Tue Sep 02, 2025 6:27 pm
by Mark Chaffin
More progress. Almost ready for paint.
Posted: Tue Sep 02, 2025 6:31 pm
by Ed Fuller
Wow, a winch!
That must be a serious ranch!
Progress looks great Mark.
Posted: Tue Sep 02, 2025 8:00 pm
by big2bird
" Nothing runs like a dear Ford."
Posted: Thu Sep 04, 2025 7:32 am
by Shrshot
Mark, That is absolutely fantastic! Really like the fenders and the winch set up. Can't wait to see it in paint. Hats off to you sir!
Posted: Thu Sep 04, 2025 10:44 am
by Mark Chaffin
Fun making something different for a change.
Posted: Sat Sep 06, 2025 1:32 am
by AndreFordT
Good morning Mark,
Great project, I would like to see the finished produced.
Do you have photo of way you attached the rear fenders to the rear axle?
Andre
Belgium
Posted: Sat Sep 06, 2025 6:54 pm
by Mark Chaffin
Andrea. I'll take a few pics and add them on Monday.
Posted: Tue Sep 09, 2025 2:46 pm
by Mark Chaffin
Posted: Tue Sep 09, 2025 4:30 pm
by AndreFordT
Thank You Mark.
Andre
Belgium
Posted: Wed Sep 10, 2025 11:18 am
by big2bird
Mark. The Blockneys. Are they marked " Made in the UK."?
Posted: Thu Sep 11, 2025 7:25 pm
by Mark Chaffin
Made in Vietnam.
Posted: Thu Sep 11, 2025 11:36 pm
Made in Viet Nam, to Blockley's own specifications. They have been supplying a large range of bias ply and vintage racing tyres for many years. They recognised there was a real quality problem with the quality of the tyres produced for our Ts, and set about rectifying this. What it needed was direction from the marketer for those better quality products. That better quality comes at a higher price, but as someone commented on the forum, if it leads to longer, better service, it is far better value over all.
Posted: Fri Sep 12, 2025 10:24 am
by Mark Chaffin
My opinion. Far superior to the other offerings. Especially, their tubes.
Posted: Wed Oct 01, 2025 5:25 pm
by Mark Chaffin
All done with assembly. Time to taker her apart for paint!
Posted: Thu Oct 02, 2025 3:32 am
by Henry K. Lee
LOOKING GOOD BIG DAWG!
Posted: Sat Oct 04, 2025 7:03 am
by AndreFordT
I should just get satin clear coat to keep the rust aspect.
Andre
Belgium
Posted: Sat Oct 04, 2025 9:14 am
by Shrshot
I can't wait to see it in paint done. That is a awesome build!
Posted: Sat Oct 04, 2025 12:07 pm
Mark Chaffin wrote: βTue Sep 02, 2025 6:27 pm
Where did you get the cycle fenders & what are the dimensions? Been looking to get some
Posted: Sat Oct 04, 2025 12:44 pm
by Mark Chaffin
I made them. About a 24" radius. Modified early fender brackets front and rear and attached with threaded rivits.
Posted: Wed Oct 22, 2025 5:25 pm
by Mark Chaffin
Couldn't help myself. Added the Vega box and extras for better steering.
Posted: Wed Oct 22, 2025 6:57 pm
by big2bird
I saw it today. Took the same pictures. It's a beauty Mark.
Posted: Fri Oct 24, 2025 11:15 am
by frontyboy
Mark,
Really incredible project very creative and well thought out and constructed. I do have a question about the seat. I'm guessing it is molded wood construction. Is it new and if so Did you make it or did someone else do it. I'm looking for that style of seat for my 1914 speedster project I'm working on now.
thnx
frontyboy
Posted: Fri Oct 24, 2025 11:55 am
by Mark Chaffin
Ray Wells made the seat and Ernie Romero the upholstery. They are both the best when it comes to their skill and craftsmanship.
