Why is the intake runner so darn long??
Posted: Sun Mar 16, 2025 10:09 pm
by drzomber
I'm new to T's (I have had a bunch of A's in the past) and don't understand why they make the intake runner so long. Even on aftermarket intakes (except for the Winfield) it seems excessive. I guess I could understand it if they were building a high revving engine but given the application it seems really odd to me. Can someone explain the reasoning to me??
Re: Why is the intake runner so darn long??
Posted: Sun Mar 16, 2025 10:20 pm
by Ed Baudoux
I believe that the length of the intake drop is intended to allow enough drop for the gravity fuel system. Some earlier body styles had a longer drop.
Posted: Mon Mar 17, 2025 8:25 am
by Tadpole
If you think Ford was bad, look at Chevrolet’s!
Posted: Mon Mar 17, 2025 9:22 am
Longer, small bore intake manifolds work very well on low speed engines with mild cam profiles. Short, large bore intake runners with no manifold heat would give very poor results on a stock Model T engine, especially with the gasoline commonly available in the 1920s. An intake manifold can be "tuned", much as an exhaust header can be "tuned". Modified T engines that run at higher speeds with high lift, long duration camshafts and larger carburetors can take advantage of shorter, larger-bore intake runners.
Posted: Mon Mar 17, 2025 7:38 pm
by Erik Johnson
As Ed posted above, the gravity flow fuel system is the reason the carburetor sits so low and the intake is so long.
My father's 1910 IHC Model F roadster has overhead valves and has a much longer intake than a Model T Ford.
Posted: Mon Mar 17, 2025 8:13 pm
by got10carz
Here's my theory. The firing order is wrong. The model T is 1243 as are most early 4 cylinder cars. This requires the front 2 cylinders and rear 2 cylinders to suck 1 right after another. The long manifold has more fuel stored in the manifold. A better firing order would be 1324.
Posted: Mon Mar 17, 2025 9:52 pm
by Craig Leach
The firing order on a T does as I understand causes a flow issue that would be rectified with a 1423 or 1324 configuration. Reversing the ports
has been tried with some success as I understand. Now that cams are being manufactured again maybe someone will bump the program & make
some. Kirk Wright built a 6 cylinder out of T engines & somewhere there are pics of him making the crank & cam. A stock came could be cut up
& put together to do this also. Didn't Winfield's 2up 2down engine have a modified firing order?
Craig.
