Hi Fellow Model T'ers
In this video I walk you through step by step how to replace the front wheel bearings on your Model T, from driving out the old bearings to installing the new ones, and the learning curve along the way!
https://www.youtube.com/watch?v=SMbotPkpqMc
VIDEO: How to Replace Front Wheel Bearings on Your Model T
Topic author - Posts: 65
- First Name: Mitch
- Last Name: Taylor
- * REQUIRED* Type and Year of Model Ts owned: 1924 Ford Model T touring
ModelTMitch
Website: https://www.fordmodelt.net
YouTube: https://www.youtube.com/@ModelTMitch
Twitter: https://www.twitter.com/modeltmitch
Car Club: https://www.glhac.org
- Last Name: Pawlowski
- * REQUIRED* Type and Year of Model Ts owned: 1925 Roadster
- MTFCA Number: 49635
Re: VIDEO: How to Replace Front Wheel Bearings on Your Model T
I enjoyed your video and find, at least for me, watching the repair being done is much better than reading the process in a manual. After this video I watched the replacing transmission bands video. It was lacking on how to adjust the bands though. You do have a video on adjusting the bands, however, it only covers the low band adjustment. Will there be a video on the proper procedure to adjust the brake and reverse bands? Also as series of videos on the rebuilding of a rear axle would be amazing.
John, adjusting the bands on a RHD car is much different to the procedure on a LHD car. On RHD cars only first gear band is adjustable on the inside. I could not tell whether the car in the video is R or LHD. The lack of holes either side of the split in the rim may mean it is a LHD car, as our Canadian sourced RHD cars have rims with holes to accept a special tool to collapse the rim.
Finding ball bearings in a car late enough to have 21" split rim wheels is not usual. Tapered rollers came in well before that, so the changeover as shown is not the usual finding. The method of adjusting the load on the threaded bearings is quite different. Using the cheaper bearings with the slide on collar for the outer bearing makes adjusting the bearings for the correct running fit somewhat easier. With that style of bearing, I wonder what role the notched washer plays, other than to keep it there for later use when threaded bearings may be fitted.
- First Name: Mitch
- Last Name: Taylor
Hi John,
I do have a video on how to adjust the bands, it's been on my channel for the past two years
I know it's limited, but it gives you an idea I will have to publish an updated version soon :
https://www.youtube.com/watch?v=vuAnyYOvHxc
Enjoy
Enjoy
25 roadster john wrote: ↑Mon Jun 24, 2019 2:11 pmI enjoyed your video and find, at least for me, watching the repair being done is much better than reading the process in a manual. After this video I watched the replacing transmission bands video. It was lacking on how to adjust the bands though. You do have a video on adjusting the bands, however, it only covers the low band adjustment. Will there be a video on the proper procedure to adjust the brake and reverse bands? Also as series of videos on the rebuilding of a rear axle would be amazing.
ModelTMitch
- First Name: Mario
- Last Name: Brossard
- MTFCA Number: 30981
- MTFCI Number: 30981
Hi Mitch,
I love all videos you made. It is really cool and helpfull. Also very nice done. Thank you taking time sharing it with us. I thought a video how to adjust a timer will be cool too.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
