Model T Power Plant info
Posted: Sun Mar 23, 2025 4:15 pm
by jawa
I just picked up this old power plant and have never seen one like it. No transmission, just a large cast flywheel. Also, heavy cast mount for the oil pan. Looking for information about what it could have been used for and was there a company that made these conversion kits.
Thank you
Adam
Re: Model T Power Plant info
Posted: Sun Mar 23, 2025 8:18 pm
by Les Schubert
Some of it resembles my Roberts marine engine.
It has a cast aluminum pan that certainly resembles yours. The flywheel looks very similar. I suspect that it has a oil pump
Posted: Sun Mar 23, 2025 8:47 pm
by jawa
Would the oil pump be in the pan? What would run it?
Thanks for the info
Posted: Sun Mar 23, 2025 9:41 pm
Normally mounted on the cam instead of a timer.
Posted: Mon Mar 24, 2025 11:03 am
Thanks for the info
The oil pump...
A plunger type pump, run off of a cam lobe.
Posted: Mon Mar 24, 2025 2:43 pm
by jawa
Ok. Thank you. I think this is a cool setup.
Posted: Mon Mar 24, 2025 5:09 pm
by Harley_97
Interesting that it has an accessory water pump drawing from the bottom of the radiator pumping into the rear of the head. It looks to have the one-piece valve cover making it 11/1/21 or newer. Does it have a casting date or a number stamped in the boss above the water inlet?
NOV 1 Engine production records, Ford Archives
First engine with one-piece valve door. The older two-door engines continued until April 3, 1922.
Roger
Posted: Mon Mar 24, 2025 7:10 pm
by jawa
According to the engine number it is a 1924. Is there a lot of these out there? I have had a few stationary setups but they all have had transmissions attached. The way this is setup it looks like maybe a company made a kit to build it with a special oil pan, cast timer cover replacement to run the water pump and external mag, etc.
Adam
Posted: Fri Mar 28, 2025 6:51 pm
by jawa
Anyone else ever seen this type of stationary setup??
Posted: Fri Mar 28, 2025 7:55 pm
by George House
I really don’t think of it as stationary but concur with the boat power plant suggestion. Never seen intake and exhaust manifolds position like that but carburetor location suggests operator isn’t concerned with hills. :lol:
Sure would be loud tho’
