Some reassembly required
Posted: Mon Jun 24, 2019 9:46 pm
Now I have to get it put back together. :D
Re: Some reassembly required
Posted: Mon Jun 24, 2019 9:59 pm
by Steve Hughes
Nothing like the incentive program. I have confidence you can do it.
Posted: Thu Jun 27, 2019 11:08 pm
by Joe Reid
Did you rebuild your engine? Are you driving your 15 or your 23?
Posted: Thu Jun 27, 2019 11:39 pm
It will be the 15 again. The engine is at Mike's in Tulsa, and I'll be going down Monday for another work day. I hope to have it back in the car in a couple of weeks so I can spend August breaking it in and getting ready to go.
Posted: Fri Jun 28, 2019 2:12 am
by George N Lake Ozark
I'm curious on how well the scat crank will work for you.
Posted: Fri Jun 28, 2019 7:31 am
by Gonenorth
Steve, you will love the SCAT crank. Engine runs smoother and no more worries about participating in the two-piece lottery.
Posted: Sat Jun 29, 2019 12:10 am
by Joe Reid
Steve, are you coming up to the Iola Car Show? Sounds good about your 15.
Posted: Sat Jun 29, 2019 12:19 am
Hmmm... That's week after next. I hadn't thought about it, but maybe I should head up that way and get out of the heat for a few days.
Posted: Sat Jun 29, 2019 10:01 am
Beware on the Scat crank. The front horseshoe bolt comes too close to it, and I think I had to dish the horse shoe a bit too.
Posted: Sun Jun 30, 2019 3:57 pm
by modeltbarn
It's the rear hose shoe, not the front one...... there's lots of clearance for the front one, I finished my engine up the other day and went through that. Just use a 1" long 5/16" bolt, cut the head off, put it in the center rear horseshoe hole, weld it, then grind the horseshoe as needed. I'ts really easy to see this with the inspection pan off.
With Mike working on your engine he'll take care of it for you.
Posted: Sun Jun 30, 2019 4:33 pm
Yep, I believe he already did. Last session we got as far as trying to install the main shaft without any runout. When we couldn't do any better than .002" we quit that and did the front axle instead. I'm going back tomorrow with a box of main shafts in case we want to look for a better one.
