Jim,
The DC and AC discussion was in reference to post #2 in this topic where it was stated that LED’s run on DC and not AC.
Then they went on to discuss using a rectifier with 4 diodes making a bridge rectifier.
It is an often repeated mistake about LED’s and AC power.
As long as it is within product limits it works fine.
That said, ALL of the LED bulb assemblies ready to install contain multiple parts and usually not just LEDs inside.
Depending on what components were used and how it is hooked up it can become almost anything.
There is a huge variety of bulbs out there so pick what you want and if unsure talk to the seller and verify it is right for your use.
The bulb that you referenced is very interesting and might work.
[image]
- LED Bulb.jpg (19.15 KiB) Viewed 2720 times
I have not tried them and do not have a mag headlight car. I skip from brass to starters in my fleet.
Here is my opinion on them, I do have a few concerns/questions about them.
Brightness, current, lifetime, color, size and materials all look good.
The double sided construction is good but it has to be rotationally aligned for the proper light pattern. Did the pins on the base get aligned correctly?
It uses the stock reflector, does it place the light at the correct depth to be able to have a decent focus?
The socket (Part #6574X) will have to be changed to install this. I do not know of a BA15S socket with screw tab to install in the headlight bucket. Not sure how to solve this without creating custom parts. I have installed single pin bulbs in dual pin sockets with mixed results. No matter what the stock wiring MUST be reworked to avoid shorting the magneto and burning out the wiring.
It has a wide voltage range with a built in voltage regulator and this is what is needed for a magneto bulb. But I believe the stock dimmer assembly will produce a car with 2 high beam settings. This may or may not be a problem.
I am concerned about the comment in the listing about maybe needing a resistor to fix a flickering issue or poor low beam operation. I don’t know enough about this to make judgment here.
I am also concerned about burning out the bulbs when running high speed with a hot mag. The rating is up near the voltage limit so it should work. But the magneto power is noisy power, there might be garbage and spikes that will damage the bulbs? I don’t know how strong they are at the upper limits. I worry about this because I have burned out several electronic things on my car due to this including my Arduino GPS Speedometer. It worked great on my modern cars for many hours and Rusty (my 26 touring) smoked it dead in about 1 block.
I would love to be able to recommend a good solution to the headlight problems on the Magneto bulb cars. So far all I can recommend for high quality long lasting light is to convert to the battery light setup. Like Steve hinted at, the magneto bulbs you get today are not very good.
In reference to Steve’s original question: There is no drop in, no modification replacement LED bulb for our Magneto headlight cars that I have ever seen or heard of. I wish there were, but things are evolving so in the future, maybe.
I hope someone will report about these bulbs or document how to install them in a magneto car.
They have me curious and I would like to know how they work.
I am also curious if there is something else out there that might work that I don’t know about.
Other references:
https://www.mtfca.com/discus/messages/8 ... 1531884556
and
viewtopic.php?t=41086
Mike
