20's differential in 1913 rear axle housings?
Posted: Wed Apr 09, 2025 7:03 pm
by MMorse
Good evening. The subject pretty much sums it up. I've got a 1913 rear axle with very worn parts, including the spider and spider gear bushings (yes, bushings). Would the guts (differential) from an early 1920's rear axle fit into the 1913 housing without any fitment issues?
Thank you!
Re: 20's differential in 1913 rear axle housings?
Posted: Wed Apr 09, 2025 7:36 pm
by Dan McEachern
yes, everything will fit the same as the earlier parts.
Posted: Wed Apr 09, 2025 8:47 pm
by MMorse
Okay, thanks. That’s what I understood but was second guessing myself. I appreciate your help.
Posted: Thu Apr 10, 2025 8:51 am
by Dan Hatch
That is the beauty of a Model T. Most mechanical parts are interchangeable between the years. It was planned that way.
