Easiest way to pull rear axle inner oil seal once bearings and sleeves are out??
Posted: Wed Jun 26, 2019 6:49 pm
by RxGPoblet
Hey all,
Hoping someone has an easy way to pull the inner oil seal in the rear end so I can put newer neoprene ones in while I have it apart. Is There a tool that can be purchased/manufactured? Not sure what is in there now cuz' all I can see is the washer but am pretty sure when it was rebuilt last neoprene was just a chemist's dream. Thanks for your ideas, Tried a bent piece of wire but a piece small enough in diameter to go between axle and washer wouldn't seem to do the job.
PS Note to self sleeve pulling tool worth every penny
Re: Easiest way to pull rear axle inner oil seal once bearings and sleeves are out??
Posted: Wed Jun 26, 2019 7:22 pm
Try a oxy-acetelyne welding rod or any long piece of rod that’s stiff enough and a larger diameter than a piece of wire.
Posted: Wed Jun 26, 2019 7:25 pm
A steel coat hanger wire will work IF you can still find one !
Posted: Wed Jun 26, 2019 7:28 pm
by RxGPoblet
Got plenty of old wire hangers but was to big diameter to go between washer and axle or housing
Posted: Wed Jun 26, 2019 7:30 pm
by RxGPoblet
Aaah. Brainstorm. I have an extra piece of brass stock I used to make a new choke pull. Bet that would do it. Will get back to yall.
Posted: Wed Jun 26, 2019 7:46 pm
by RxGPoblet
Got it out. Thanks for help. Just needed to get brain in right mode. Leather and spring so glad I got it out.
Posted: Wed Jun 26, 2019 11:46 pm
You're doing the smart thing. Sometimes the metal parts of those old leather seals will score the axle shaft until it breaks.
