Spring is here.
First Name: Dallas
Last Name: Landers
Spring is here.
Post by Dallas Landers » Mon May 05, 2025 11:50 am
I pushed the 26 RPU in the shop a couple weeks ago to do all the normal lube and adjustments. Oil change adjust Rockies and bands if needed. Fix a small gas leak at the shut off ect.. well Sunday I finally got to spend the day in the shop. I was amazed at how much debree was in the screen in the tank shut off. Not rust but lint, bugs ect... it was 1/2 full.
Now the Joe Bell engine has always been an easy starter and Scott's full flow valve is awesome. After going over everything I decided it was time to fire it up for the first time since September. It started and ran like a dream with the 1st pull on the crank after two priming pulls of course.
JohnM
Last Name: Michaelree
Board Member Since: 2010
Re: Spring is here.
Post by JohnM » Mon May 05, 2025 5:49 pm
You literally got all the bugs out. :) It's always fun to hear them roar to life after a long slumber.
Duey_C
First Name: Duane
Last Name: Cooley
Re: Spring is here.
Post by Duey_C » Tue May 06, 2025 8:13 pm
No nonsense machines. Great report Dallas!
Last Name: Hjortnaes
Re: Spring is here.
Post by DHort » Wed May 07, 2025 2:04 am
If there are no pictures, it never happened. :)
