Fuel gauge cork float
Posted: Fri May 09, 2025 1:17 pm
by South Park Zephyr
I recently received an aftermarket fuel gauge that I bought from Jay Buscio. It looks great, but age has taken its toll on the cork float. Do any forum members have any advice?
While searching for a suitable replacement, I found a source of straight sided cork on Amazon. It appears that the original has a coating on it, but I read that cork is fuel resistant. The cost is minimal, but I’d rather not stress the retaining tabs on the gauge by trying multiple different things.
Thanks,
Scott
Re: Fuel gauge cork float
Posted: Fri May 09, 2025 1:29 pm
by speedytinc
Not sure what you are asking.
If you are asking what to reseal/coat it with, I have had success using "line-a-tank" on cork floats.
Its a gas tank sealer. green & white labeled quart can.
Posted: Fri May 09, 2025 2:02 pm
by Jerry VanOoteghem
I made a new cork float for my 1907 Holley carburetor. I coated it with alcohol-proof gas tank sealer. Works fine. Others have coated theirs with POR15. Originally, they would be coated with shellac, but alcohol laced fuels will dissolve shellac...
Posted: Fri May 09, 2025 2:04 pm
John,
I looking for a suitable replacement
Scott
Posted: Fri May 09, 2025 2:05 pm
Thanks Jerry
Posted: Fri May 09, 2025 2:44 pm
by speedytinc
John,
Scott
McMaster Carr sells assorted sizes of corks.
Posted: Fri May 09, 2025 2:49 pm
by RajoRacer
I modified a Model A float for a T gas gauge or buy a composite float slug from Snyder's & carve your own.
Posted: Thu May 15, 2025 5:29 pm
by Marty Bufalini
Believe it or not, I’ve used wine bottle corks and coat them.
