Wheel Building Is Critical To Our Safety
Posted: Tue May 13, 2025 4:30 pm
I renamed this post as I was concerned it was too similar to the already long discussed subject of rebuild and shim questions. This has been a very interesting and involved topic and, it is not my intent to hijack the discussion. Yet, I am hoping to have constructive criticisms and contributions to my post on the technical aspect of wheel rebuilding.
There are a few points about building wheels that have not been mentioned and should not be overlooked. Last year I disassembled about 120 wheels to process for rebuild. I lined up the individual parts to look for anomalies and was surprised by my findings. My discoveries go contrary to some opinions I have heard.
1 - After years of use, with the wheels rocking side to side, the hub flange and spoke plate are slowly bent out between the hub bolts. Tightening the bolts does not cause that. A 3/8" bolt is not strong enough to crush Hickory.
2 - The rear hubs are often misread as needing a shim, yet sometimes they may. I cleaned and fitted 18 rear wire wheel hubs and more than twenty wood wheel hubs to a new axle mounted in my vise. I noted the fit and measured the length of thread protruding. What I have discovered is, where the nut or lock washer rides, the hub gets dented in and creates a "choke" on the axle. This holds the hub out allowing it to rock causing the thought that it needs a shim. Stick your small finger in the hole and feel the burr, that needs to be removed.
With the hub mounted in my vise, I used a 3/8" coarse rat tail file first from the outside to in, then inside to out. Glide on the factory taper being careful to not to wear that area. Work your way around feeling the burr disappear. This shows the flange warp. This exceeds the volume per post so I will post again.
