LED turn signals?
MTFCA Number: 16175
MTFCI Number: 14758
LED turn signals?
Post by Steve Jelf » Thu Jun 27, 2019 3:56 pm
To install turn signals I assume I'll need six volt bulbs, a flasher, a three-way switch, and maybe a pair of indicator lights. Is there anything else? Anybody have a diagram for the wiring?
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: LED turn signals?
Post by Henry K. Lee » Thu Jun 27, 2019 3:59 pm
Steve,
Send me your email, I have plenty with options.
All the Best,
Hank in Tin-A-See
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Jun 27, 2019 4:07 pm
Steve,
If you require 12 volts to power up your LED lights, get an older 6volt to 12volt converter on the bay that we use to use on our radios. They work excellent since LED's require so little to power up.
Hank
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu Jun 27, 2019 4:25 pm
If you require 12 volts to power up your LED lights...
No, I buy six volt bulbs to match my batteries. The converter is for my phone charger.
It's Bill
First Name: Bill
Last Name: Hoffer
MTFCA Number: 32571
MTFCI Number: 24364
Post by It's Bill » Thu Jun 27, 2019 5:18 pm
Steve, if you get this done, please post the info including part numbers. I got a number of replies to my similar question in 2017 (I think), but I could not get anything to work. Hope you are successful with this! Cheers, Bill
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Jun 27, 2019 5:38 pm
A circuit diagram for my Morris is attached in the PDF, but the smoke travels the same way in the wires in a T as well ;-)
6V variants are available for the components.
The PDF is a bit of a story covering all the installation written for the Morris Club. It includes a few 'Anglo' terms, but I think you can figure them out (I trust!). I hope you enjoy it (just reverse the 'right' to 'left' for US readers ;-) )
Cheers
Adrian
Indicators.pdf
(776.82 KiB) Downloaded 56 times
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Jun 27, 2019 5:55 pm
I installed a USB charger too. Here is the notes for that:
USB Charger.pdf
(530.68 KiB) Downloaded 68 times
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Jun 27, 2019 6:27 pm
Here you go folks! Simple, works Great, the hazards are optional.
All the Best,
Hank in Tin-A-See
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Jun 27, 2019 6:58 pm
Hank, that is a nice touch and looks easy to add it in to the existing wiring. Might give it a go :-)
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Jun 27, 2019 7:04 pm
Thanks!
This is to be added not incorporated to existing wiring. If you require integrated like a modern car with dual brake lights, etc let me know and will post the schematic for it!
All the Best,
Hank
First Name: Adrian
Last Name: Whiteman
Post by A Whiteman » Thu Jun 27, 2019 7:09 pm
(sorry - meant the indicators I installed already! - see my PDF)
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Thu Jun 27, 2019 7:15 pm
Adrian,
Getting old is a World Wide Problem! LOL!
MTFCA Number: 28924
Post by John kuehn » Thu Jun 27, 2019 7:25 pm
Lang’s has a good selection of turn signal and stop light kits in the accessories section of their catalog. All the parts you need to do it with a kit or individual parts to do it as you like.
Dennis_Brown
Last Name: Brown
MTFCA Number: 21458
Post by Dennis_Brown » Thu Jun 27, 2019 10:59 pm
I have not figured out putting the flasher before the switch. Usually on a set up we would be using on a T would have 2 flashers after a 3 position switch. One for the feed to the left lights and one to the right unless you were mounting a regular turn signal control which is designed to use 1 flasher.
MTFCA Number: 16175
MTFCI Number: 14758
Post by Steve Jelf » Thu Jun 27, 2019 11:27 pm
Looks like that diagram should do it, but...
Post by TRDxB2 » Fri Jun 28, 2019 12:53 am
Here is a wiring diagram that can be integrated into the T wiring. It includes a black box (tail light converter - designed for trailer connections) to simplify the wiring to the tail lights if you have dual filament bulbs. I roughed out a diagram of the black box wiring to show what it does. Also if you are using LED Bulbs you need to get a Flasher that works with LED bulbs
Taillight Converter Box.png (9.63 KiB) Viewed 2138 times
Chris Barker
First Name: Chris
Last Name: Barker
Post by Chris Barker » Fri Jun 28, 2019 7:05 am
One word of warning.
I have the 6v system but the 18W bulbs took a lot of current (6A)
So I converted to LED and bought a flasher suitable for LEDs (the old style 'hot wire' type needs the current of a filament bulb.
It all worked fine.....until I started the engine. Then either the RF from the coils or the dirty 6VDC supply from the generator messed up the solid-state flasher.
So I put filament bulbs back in the rear lights and put the hot wire flasher back.
jsaylor
Last Name: Saylor
MTFCA Number: 1695
MTFCI Number: 23870
Post by jsaylor » Fri Jun 28, 2019 12:11 pm
Had the same issue wit the solid state flasher and LEDs. worked fine until I started the car. The flasher stopped working. I started trouble shooting using an analog VOM and found 28 volts of AC on the DC terminals. My car runs a distributor and a mid 60's 12 volt generator. Haven't had time to trouble shoot any further.
modeltmick
First Name: Michael
Last Name: Seibert
MTFCA Number: 28613
Post by modeltmick » Fri Jun 28, 2019 1:06 pm
I installed a set of Logo Lites for a model A on my T, they are easily adaptable to a T. They run on 6 or 12 volts and they work great
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Fri Jun 28, 2019 1:16 pm
Yes Steve, sorry, simple typo.
Hank
First Name: DAVID
Last Name: HJORTNAES
MTFCA Number: 28762
MTFCI Number: 22402
Post by DHort » Fri Jun 28, 2019 7:26 pm
I just signal with my left arm. No one behind me is looking for lights. They are looking at me.
