26-27 running board brackets
Topic author - Posts: 128
- Last Name: Davis
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
My running board brackets seemed to be bent. Should they be parallel to the floor. Also, what can I use as a reference for the brackets fore and aft. Im planning to bend them with a piece of pipe. Anybody have a better idea. Thanks
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Re: 26-27 running board brackets
Google: model t frame dimensions mtfca and you can print it.
Ken
Ken
Work honestly
Stay true to your word
Get the job done right
- Last Name: Humble
- * REQUIRED* Type and Year of Model Ts owned: 1926 Canadian built coupe, 1924 TT C-cab, survivor 1924 roadster
- MTFCA Number: 28034
Should be parallel to floor.
- Last Name: Bartsch
- MTFCA Number: 30615
Make sure the frame of the car is 'parallel' with the plane of the floor before you adjust brackets. I have seen front RB supports on the '26-'27's reinforced with a piece of square tubing bolted across the underside of the of the bracket full width of the car. I think they used 1" square tubing and running board bolts ~2 inches longer than stock on the front bracket. Doesn't work for rear b/c driveshaft interferes. Not stock, but an effective solution to strengthening the structure. jb
- MTFCA Number: 4838
- MTFCI Number: 115
This is helpful drawing, while not Ford work, dimensions are very suitable for stock '26-'27 frame.
