Rear axle dumb question of the day
Posted: Sat May 31, 2025 1:43 pm
So I'm in process of setting up my rear axle.
The original thrust bearing washers ate thru the pins and subsequently dropped enough to chew into the diff carrier collar. Assembling the new means setting the washers with some grease to hold in place and keep the plates dropping off the pins. The goal, both for rebuild, as well as operation, is for those thrust plates to be stationary sandwiching the floating brass plate.
Both of which got me thinking...
Has anyone ever considered, or actually done, gluing the pinned plates with JB Weld?
Positives:
* makes assembly much easier considering the multiple times the halves must be fitted (but requiring temporary full set up in order to ensure as best alignment as possible to set up in place)
* keeps the plates in place and eliminates risk of coming off the pins and destroying the diff carrier or worse
* reduces sheer movement of the plates from eating the pins in the first place
Negatives:
* difficulty in properly setting and potential of introducing misaligned thrust plates
* inability to introduce shim plates
* nobody would want to face the prospect of rebuilding a glued up axle in the future
* lazy way out of properly taking time to set up the axle
So, pretty much have answered my own question relative to not being a good idea, but was curious whether anyone has ever done so, and if so, your reasons. I did various word searches on glued thrust plates and got nothing, but I can't possibly be the only one with such a hair brained idea!
Fire away! I know lots of opinions exist here! LOL
Positives:
Negatives:
