Adding a drain hole in a Ford-Fathful oiler?
Posted: Thu Jun 05, 2025 8:20 pm
Has anyone added a drain hole at the bottom of the lower plate, so you don't dump so much oil when you take it off? If so, what size did you use? While not a huge amount, it still dumps a lot of oil when you take if off. As most know, a little oil goes a long way making a mess!
Re: Adding a drain hole in a Ford-Fathful oiler?
Posted: Thu Jun 05, 2025 8:36 pm
Read on https://www.mtfca.com/discus/messages/8 ... 1528387567
Posted: Thu Jun 05, 2025 8:47 pm
LOL I posted on both of those! Thanks for pulling that info.
Posted: Thu Jun 05, 2025 9:16 pm
by Wayne Sheldon
Been a long time since I had one of those Ford Faithful oilers. However I do really like them.
As I recall, that little weep hole often plugs up with the myriad bits of debris and band lining material. I usually packed some paper towels behind the FF oiler before removing it. Usually, I could catch most of it.
Posted: Fri Jun 06, 2025 2:21 pm
Last night when I pulled mine (not glued together) most of the oil poured out the sides and down the hogs head. Luckly I had the drain pan in the right place and caught most of it.
I went with 3 places and a little bigger then shown in the above photo, 3/32. Looking at the one in above, think it is bigger than 1/32. Drilled one where it is shown and one each corner at the bottom. As much oil as was pushing out the top where I needed to seal better, at a fast idle, think they will be ok until getting pluged up as Wayne said.
Posted: Fri Jun 06, 2025 2:48 pm
Consider, that when the drain hole is open, it will drain as designed for removal, still filling & keeping full the reservoir pocket that feeds oil out to the front of the motor.
On a related note, the unit shown doesn't have a screen to filter out the chunks. The FF base units I have seen normally have a screen spot welded inside to catch the chunks. Coincidentally?, the screen mesh is about the same mesh size as the drain off hole.
