Carburetor Recommendations
Posted: Sat Jun 07, 2025 10:52 am
I'm starting a new thread to specifically talk about carburetors. The T I've got came with a Zenith-Bendix side draft unit originally installed on a Wisconsin Twin cylinder engine. It ran OK, but had a sloppy throttle shaft, wept fuel when not running, and didn't have any way adjust the mixture, which ran pretty rich.
While the ultimate goal is to get an original-ish carb setup on the car, coming up with the parts to do it will take time and/or money. So, in the meantime, I cobbled together a temporary solution.
The carburetor is a $28 knockoff copy of a Marvel-Schelber updraft for a Ford 9N/2N/8N tractor application. A right-angle elbow of 1-1/4 OD stainless tubing gets the mixture into the original Vaporizer manifold. The throttle linkage is supported by a two-piece shaft collar, and a bell-crank gets the crossways throttle rod coming over the head to go up-down to run the butterfly. It manages to use pretty much the whole throttle quadrant between idle and wide open, so the control seems fine enough. Topped it off with a $8 motorcycle filter. So, how does it run? To be honest, it's the best-running Model T I've ever driven, even if it is the only Model T I've ever driven. Pops in about 4 revolutions with the choke on, usually one more crank and it's running. Crisp response once it's warmed up, seems to pull well. In Hi-Hi, it has no trouble hitting 45 depending on grade and wind. Cruise at 35 is only about 1/4 way down on the lever. It seems to pull well up the hills I've driven so far. Judging by the spark plugs, I've got full-load mixture dialed in right.
For $50 in parts and a couple hours of shop time, it works pretty well. I guess my question here is will moving to a rebuilt NH or other period carb actually gain me anything beyond "correctness" ? I'm sure I can refine this setup - a more flow-friendly induction by either brazing a flange onto a standard intake, or installing a Winfield-style intake. I'll need a standard exhaust manifold then, of course. And while it isn't a 110 year old setup, the tractor carburetor is still a 90 year old design and dead simple to tune and repair.
