Chicago Mark-E Aux Transmission
Posted: Tue Jul 01, 2025 7:05 pm
by Bryant
Looking for information pertaining to the Chicago Mark-E Auxiliary transmission.
What I am looking for
Literature on installation
Original sales ads and the like
Part sources, part numbers
Rebuild specifications/tolerances
Information on manufacturing dates
Information on the round disk with the grease zerk pictured below.
And any other interesting things we can come up with.
Re: Chicago Mark-E Aux Transmission
Posted: Tue Jul 01, 2025 7:08 pm
by Bryant
Bryant
Posted: Tue Jul 01, 2025 7:53 pm
by Michael Peternell
Try Tim Morsher, I sent him a few, he went through them and with his transmissions we both ended up with one. The ones that have patent pending on the case have bearings that seem to be made out of unatainium. Bearings on the later ones are easier to get. Tim can probably explain better.
For what it's worth!
Mike Peternell
Posted: Wed Jul 02, 2025 6:27 am
by Bryant
This one doesn’t have the patent pending on it.
Says FO-1
hopefully an Obtainable model.
Bryant
Posted: Sat Jul 05, 2025 7:35 am
by Bryant
Also looking for a source for a transmission mount/brace. It probably wouldn’t be to much different than a Warford set up. Or any pictures of such a thing.
Bryant
Posted: Sat Jul 05, 2025 9:35 am
This older post has pics of the bracket.
https://share.google/WOg6e4p3l45PrG8Wv
Posted: Sat Jul 05, 2025 2:30 pm
by Bryant
Thanks for that. I was looking through older posts but did not see this one.
What a bracket! Has its own suspension.
Thanks Dan
Bryant
Posted: Sat Jul 05, 2025 7:24 pm
by Bryant
Putting the round disk in place I realized it’s purpose. Giving just enough spacing so the brake equalizer doesn’t hit the transmission. Pump it full of grease for an oil seal.
Bryant
Posted: Sun Jul 06, 2025 11:01 am
There are work arounds that eliminate that spacer by making your own equalizer. I have made a couple like shown in the link. Instead of the round rod with brake levers attached at each end, I just used flat bar with ends folded down. These allow the U part to be extended down to give more clearance for the transmission. I have not calculated the force applied but seem to work.
https://www.mtfca.com/discus/messages/3 ... 1384711491
Posted: Sun Jul 06, 2025 1:14 pm
by Bryant
I actually like the simplicity of the spacer. However to get it installed I believe it will require studs. The through bolts would need to be to long to be able to get them to fit into the holes.
Posted: Sun Jul 06, 2025 1:18 pm
by Bryant
Thanks for the link Mark! I like the idea.
Now for another issue…..
the running board brace is now in the way. Is this normal for Aux transmission installations? I just love a challenge.
It’s a 26 Tudor
Bryant
Posted: Sun Jul 06, 2025 1:49 pm
Just a "heads-up" - the starter switch installed in your photo is NOT a good reproduction - it might work a few times, but the button rivet usually comes from together & launches the button or gets stuck engaging the power - not a good scenario !
Posted: Sun Jul 06, 2025 2:11 pm
Yes. Cutting the front running board channel is a must for these trans.
This older post has a great write up on install of several types, but not the Mark E
https://share.google/pQHtf6DScZ85zGlzd
Posted: Sun Jul 06, 2025 2:30 pm
by Bryant
When I took the picture I thought to myself. “I wonder if anyone will say anything about my starter button” LOL! Yeah I bought that when I got the car before I joined MTFCA. I have read the stater button topics. Yet again I will be re engineering a part…. Unless a good original shows up on the classifieds.
Bryant
Posted: Sun Jul 06, 2025 2:35 pm
by Bryant
Thanks again Dan! I guess I will sacrifice the part. :( But looking at the piece that is cut out I see a possibility to re-purpose it for a trans mount. It’s got that shape to it.
Thinking….
Bryant
Posted: Sun Jul 06, 2025 10:51 pm
Located an image of the Mark E support brace. Likely for the TT, but gives the idea of design.
Posted: Mon Jul 07, 2025 9:10 am
by Bryant
What a beauty! Where did that come from?
And is there more?
Bryant
Posted: Mon Jul 07, 2025 2:51 pm
by Bryant
main input shaft. Zoom in for details! she has seen better days. Sad but true this hobby sometimes.
Looking for one in the classifieds but also talked to a friend of mine that’s a retired machinist.
He said “ I can make that”
A glimpse of hope
Bryant
Posted: Fri Aug 01, 2025 9:07 am
by Bryant
Received another chicago to try to build one out of two.
Some Notable differences. The black case is the F0-1 case and the rust colored one is the Patent’s pending F-1 case.
Posted: Fri Aug 01, 2025 9:13 am
by Bryant
The F0-1 case seems to be more robust. The input flange is thicker, the webbings thicker.
Posted: Fri Aug 01, 2025 9:19 am
by Bryant
The input bore on the F-1 case is a smaller diameter. This makes the preload collars different diameters and the input shaft bearing is taller but not as wide.
Posted: Fri Aug 01, 2025 9:27 am
by Bryant
The input shaft difference
F0-1 case has a removable input shaft that is about an inch longer to accommodate for the trans spacer. The bearing retainer that screws on to secure the bearing has a larger diameter due to the preload screws diameter difference. Then there is the bearing size difference.
I haven’t seen anything else that has stood out after that. Lot of good gears in the F-1 case so Iam happy to start getting this thing assembled.
Posted: Fri Aug 01, 2025 9:34 am
by Bryant
Iam thrilled to have a good main shaft!
I was worried I was out of business. It would have been near impossible with out great club members!
when in doubt just ask.
Bryant
Posted: Fri Aug 01, 2025 12:33 pm
by Bryant
this logo appears on gears and shafts all over. Anyone recognize the logo?
I see letters F,I,G,H,C,T maybe…
Bryant
Posted: Fri Aug 01, 2025 2:02 pm
In case you didn't get to this link https://www.mtfca.com/discus/messages/3 ... 1385651181
Posted: Sun Aug 03, 2025 1:53 pm
by Dave Foley
Thank you for all the information and discussion on the Chicago transmission F1 and others , i have a Chicago F1 i got with a pile of parts and the discussion prompted me to clean it up and am also looking for a part, a inner bearing retainer preload for main shaft . see below in pictures ill put it in the classifieds WTB. Does anyone have any detail on assembly preload and how to set up these? how does the center retainer work? and how would you get it off the shaft? I have left the transmission assembled so i don't hurt something
The transmission was well protected by ancient grease and bearings and gears appear in good shape with shifter and knob.
i wanted to share the crossmember bolt and spring mine came with, as well as stamped number on transmission, I appreciate all the information shared
learning every day, sorry about picture orientation Thanks Dave
Posted: Sun Aug 03, 2025 11:07 pm
by Bryant
it simple threads on. It was standard direction thread. The F-1 case has a smaller input preload collar that the F0-1 so the bearing retainer will have to match its ID. A machinist could easily make this collar knowing your two measurements. (Threads and preload collar ID) my donor trans unfortunately did not have this part intact. Preload tolerances are still a mystery to me so if anyone has the information please let us know.
Bryant
Posted: Mon Aug 04, 2025 8:42 am
by Dave Foley
Thank you for the information will put a WTB in classifieds
Posted: Mon Mar 16, 2026 1:54 pm
by Bryant
Does anyone know how much gear oil these things hold of hand?
Bryant
Posted: Mon Mar 16, 2026 2:59 pm
Link above shows side view of lower drain and upper oil plugs. Last few posts on link note you can fill via the shift lever cap, would think full lube would be level with top oil plug.
