Find the 'Ford'
Posted: Thu Jul 10, 2025 1:46 pm
by 1925 Touring
It's always fun, to me, when working on the T, to look for where there is 'Ford' stamped into each and every part. I thought this would be a fun thread to have, posting pictures of all the 'ford's on our Fords.
Here's one, on a rear axle shaft.
Where's the ford on your car?
Re: Find the 'Ford'
Posted: Thu Jul 10, 2025 1:59 pm
by speedytinc
Thats a fine idea.
However, in a semi related vain, you would do well to get rid of those solid repop hyatt replacements.
Slightly worn hyatt's would serve you better. Solids are hard on axle shafts.
Look for past discussions on the topic.
Re: Find the 'Ford'
Posted: Thu Jul 10, 2025 2:31 pm
by FundyTides
Great idea! There could be a subcategory of "Made in Canada" stampings. Here's one on a "slightly used" 26-27 runningboard. If you think this should be a seperate thread, that's ok too.
Re: Find the 'Ford'
Posted: Thu Jul 10, 2025 3:42 pm
by 1925 Touring
The more the merrier
Anything T related with Ford on it.
It's amazing all the places it can be found.
Re: Find the 'Ford'
Posted: Thu Jul 10, 2025 3:49 pm
by Daisy Mae
Re: Find the 'Ford'
Posted: Thu Jul 10, 2025 6:24 pm
by FundyTides
Here's my 27 motor with Ford Made in Canada on it and a 27 front hub showing Canada on the tag. I'll have took but I think Ford is also stamped on the hub
Re: Find the 'Ford'
Posted: Fri Jul 11, 2025 2:48 pm
by TRDxB2
Door latch
Spring Clip & Bar, Ball cap, Spindle bushings, tie rod yoke (click on photo to zoom in)
Re: Find the 'Ford'
Posted: Fri Jul 11, 2025 4:25 pm
by Steve Jelf
Re: Find the 'Ford'
Posted: Fri Jul 11, 2025 9:26 pm
by CDooREDW
Re: Find the 'Ford'
Posted: Sat Jul 12, 2025 7:59 pm
by 1925 Touring
Re: Find the 'Ford'
Posted: Mon Jul 14, 2025 1:46 pm
by MarkS
The OP didn’t specify that the “Ford” logo needed to be an original part, so here is my submission.
I added an electric stop light to my ‘15 touring, which meant i needed a stop light switch. The switch being near the trans inspection cover, I was worried that a tool might inadvertently short out on the exposed wire terminals when working down there, so I 3D printed a switch cover (black, of course) and decided it needed an “authentic” Ford logo.
Re: Find the 'Ford'
Posted: Mon Jul 14, 2025 3:03 pm
by Original Smith
In this hobby, I got the name Original Smith because of that. I was in my early 20's and was always looking for NOS parts with the Ford script. There was a junk yard in Gardena, that had bins of parts that came from an old store in Los Angeles called HENRY'S and LIZZIES. That is where I used to find a lot of those parts. I used to work there on weekends for free, and was rewarded with lots of those NOS parts for my time.
Re: Find the 'Ford'
Posted: Mon Jul 14, 2025 8:28 pm
by love2T's
Here's some from Keith Gumbinger.
Re: Find the 'Ford'
Posted: Mon Jul 14, 2025 9:34 pm
by Bryant
Hogshead. One of the bigger ones
Bryant
Re: Find the 'Ford'
Posted: Mon Jul 14, 2025 10:22 pm
by KeithG
I haven't yet mastered posting pictures on the Forum so a friend posted these pictures for me just a few posts above.
The first one is a crankshaft with the script and part number shown and towards the bottom is a logo with a T over a W, which stands for Transue Williams, a common Ford parts supplier. You will note that this is a broken crankshaft and that it is a "diamond" shape between the rods. These crankshafts are notorious for breaking for two reasons: The diamond shape is weak and Transue Williams cranks are noted for poor quality. I will never use another one of them.
The second picture shows an original babbitt driveshaft bearing, the one that goes just behind the U Joint. Also shown in red primer is a round fellow wheel joining plate. You very rarely see these. I found this one at a swap meet and later noticed that I had them on both rear wheels on my '14 Touring. Quite rare. The last item is a castle nut from the rear spring perch on a TT truck. Why would Ford put script on an ordinary castle nut? Who knows, but I have found several others like this one.
Keith
Re: Find the 'Ford'
Posted: Fri Jul 18, 2025 10:37 am
by Dan Hatch
Here is an nos tie rod bolt.
Re: Find the 'Ford'
Posted: Fri Jul 18, 2025 8:13 pm
by 1925 Touring
Re: Find the 'Ford'
Posted: Tue Jul 22, 2025 6:00 pm
by Bryant
A different version of find the Ford.
Driving down a random back road I spotted it.
Do you see it?
Bryant
Re: Find the 'Ford'
Posted: Thu Jul 24, 2025 8:36 pm
by Allan
No.
Re: Find the 'Ford'
Posted: Fri Jul 25, 2025 7:55 pm
by Bryant
Re: Find the 'Ford'
Posted: Fri Jul 25, 2025 10:54 pm
by Allan
You don't often see this one.
Re: Find the 'Ford'
Posted: Tue Aug 05, 2025 1:22 pm
by 1925 Touring
Find the ford
Re: Find the 'Ford'
Posted: Tue Aug 26, 2025 10:03 am
by 1925 Touring
Find the ford
Re: Find the 'Ford'
Posted: Wed Sep 24, 2025 12:09 pm
by 1925 Touring
Here's an interesting one I found on the aftermarket bumper on our 24 fordoor.
Re: Find the 'Ford'
Posted: Wed Sep 24, 2025 4:03 pm
by Harley_97
Starter brushes.
Re: Find the 'Ford'
Posted: Wed Sep 24, 2025 4:43 pm
by TFan
Re: Find the 'Ford'
Posted: Sat Oct 18, 2025 6:56 pm
by 1925 Touring
Here's one you might not see that often
Re: Find the 'Ford'
Posted: Sat Oct 18, 2025 6:59 pm
by 1925 Touring
Here's a few more from this weekend's work.
Ford theust washer with block letters instead of script.
Good thing I tore that rear end apart!
Re: Find the 'Ford'
Posted: Sat Oct 18, 2025 7:04 pm
by 1925 Touring
And my personal favorite...
Pretty neat find I think
Re: Find the 'Ford'
Posted: Thu Oct 23, 2025 12:53 am
by TRDxB2
Re: Find the 'Ford'
Posted: Thu Oct 23, 2025 10:32 pm
by 1925 Touring
Re: Find the 'Ford'
Posted: Fri Oct 24, 2025 10:07 pm
by 1925 Touring
Re: Find the 'Ford'
Posted: Fri Oct 24, 2025 10:09 pm
by 1925 Touring
Re: Find the 'Ford'
Posted: Fri Oct 24, 2025 10:13 pm
by 1925 Touring
3 more from various spring leaves.
Re: Find the 'Ford'
Posted: Sat Oct 25, 2025 10:30 am
by varmint
Re: Find the 'Ford'
Posted: Sat Oct 25, 2025 11:11 am
by Colin Mavins
I think it was typical for ford to mark everything when Dad and I built a ford GPW jeep every part had either ford or an F
Re: Find the 'Ford'
Posted: Sat Oct 25, 2025 6:05 pm
by Ron Patterson
Re: Find the 'Ford'
Posted: Sat Oct 25, 2025 6:12 pm
by big2bird
TRDxB2 wrote: ↑Thu Oct 23, 2025 12:53 am
That's the rare one.
Re: Find the 'Ford'
Posted: Mon Feb 23, 2026 9:40 pm
by 1925 Touring
Re: Find the 'Ford'
Posted: Mon Feb 23, 2026 9:41 pm
by 1925 Touring
Are you a T fan?
Re: Find the 'Ford'
Posted: Tue Feb 24, 2026 12:40 pm
by rickd
Floor board starter switch.
