Radiator cleaner recommendation
Posted: Sun Jun 30, 2019 9:05 pm
by csnailnrun
My '12 radiator needs a good core cleaning... It's too hot too quick :(
What recommendations do y'all have?
Thank you!
Re: Radiator cleaner recommendation
Posted: Sun Jun 30, 2019 10:32 pm
by Ruxstel24
I had pretty good luck with CLR.
I would avoid getting it on the brass.
Posted: Sun Jun 30, 2019 10:41 pm
by gelfling
If the fins are not tightly bonded to the tubes, cleaning will not help you much. This happens with antique radiators. If cleaning doesn't improve the situation, you will have to either re-core it or buy a new radiator. I think that old radiators are the biggest reason why people can't drive their Ts more than a few miles without overheating.
Posted: Sun Jun 30, 2019 11:25 pm
by Les Schubert
Plain vinegar works well and doesn’t cause any damage
Posted: Sun Jun 30, 2019 11:32 pm
by Erik Johnson
Other causes of overheating worth mentioning:
- not enough oil in crankcase
- fuel mixture too lean
- retarded ignition timing
- poor driving technique
Posted: Mon Jul 01, 2019 2:27 am
by George N Lake Ozark
I've used Cascade dishwasher soap to degrease, Flush with water then an overbite soak with CLR . Rinsed with baking soda to neutralize.s it would also work if very careful not to spill on exterior Rinse again and fill with coolant of your choice. I haven't done this on an all brass radiator. Guess it would also work if careful not to spill on exterior.
Posted: Mon Jul 01, 2019 2:29 am
Posted: Mon Jul 01, 2019 8:27 am
by thom
CLR labels now say not recommended for radiators. Must be a reason.
Posted: Mon Jul 01, 2019 9:19 am
by TWrenn
My best luck, and best advice to cure an overheating 100+ year old radiator was, and is, to get a NEW one!
Been there, done that. 4 vehicles worth, out of 6!! Not too bad an average eh?? :lol: :roll:
Posted: Mon Jul 01, 2019 11:35 am
by Scott C.
I tried all sorts of things on my 26, vinegar, Dawn dish soap, Purple Power, Simple Green, Macs radiator cleaner, after multiple times each, none of them did the trick. Then I bought a bottle of Thermocure. It is a radiator cleaner that is made by Evaporust. It did a very good job. I have since used it on another radiator and again, it did a very good job. I did have to due it a few times. I reused it a couple of times, then used a fresh bottle. The radiators came out very clean and they cool fine. I picked it up at Walmart for about $20 a bottle.
Posted: Mon Jul 01, 2019 1:41 pm
by Lutz T Guy
Put a box of Arm and Hammer which is dissolved in water in. Run it that way for about 50 miles and grand and flush. This a old trick my dad used on his trucks.
Posted: Mon Jul 01, 2019 4:46 pm
by Scott_Conger
Phil
my guess is that he used Arm and Hammer Washing Soda...most on this forum would guess Baking Soda which is a good acid neutralizer, but not so good on radiators
Posted: Mon Jul 01, 2019 9:47 pm
by csnailnrun
Thanks for all the suggestions y'all. I had it off while I put a new cam and reset the valves. There was a bit of 'gunk' sitting in the bottom of the lower spout. I suspect the cores are quite dirty.
