Next up for Daisy, engine/tranny rebuild
Posted: Sat Aug 02, 2025 8:37 pm
by Daisy Mae
Daisy Mae being my '14 Touring. The front axle/steering assembly is restored, just about ready to button up the rear axle rebuild. I knew the tranny had issues, biggest concern being 3/8" play in the drum pack. But the engine ran very well, albeit some oil burn, and some bubbling at the head above the lower water outlet. Compression was great, bearing clearances were all good (except rod side clearances were at edge of tolerence, worst #3 being 0.011).
Supposedly one of the few things that were restored in the 60's was the engine (but why the worn tranny bearings??)... but....it also still has the original early style valves.... as good as she runs, she's on borrowed time...
Soooo. I've decided to yank the entire unit and just rebuild the whole thing, at least I'll know condition with certainty. Starting up my wish list now of parts to start collecting as budget allows.
All in all though she appears to be in great shape in the pots.
There are some curious stampings in the block deck (T, G, B, X)
One of which I gulped looking like a crack in the block, but no visible appearance externally nor in the bore, neither in all my years of engine rebuilding decades ago have I ever seen a V internal crack....crossing fingers just an old scratch.
In the meantime while all apart I'll be repainting the frame, fenders, splash & boards. Will leave the body as is for now, not bad shape. Sometime next year though I'll have a solid runner!
I don't believe Daisy will be any long distance runner, probably just local, in Florida flat....so...likelihood is rebuild maintaining more relative stock vs modified condition.
That being said, feel free to sing out with advice, suggestions, anecdotes, things you'd recommend, things you wouldn't, specific parts, etc, balanced with needs of constrained budget (eg, gulping at prospects of 2+k Scat)
Re: Next up for Daisy, engine/tranny rebuild
Posted: Sat Aug 02, 2025 10:08 pm
If you suspect that the blemish between the X and the B is crack, I doubt that it is. It looks like a casting flaw to me.
Posted: Sun Aug 03, 2025 2:30 am
by Erik Barrett
Check out the article in the latest Vintage Ford magazine for input on what you are looking at.
Posted: Tue Aug 05, 2025 3:18 pm
by Wingnut
Hey Kurt, better get ready for a trip Northward to drop her off at Joe Bell's place before snow flies, I'm looking ahead to visit with you. Wingnut
Posted: Tue Aug 05, 2025 8:44 pm
by Daisy Mae
Hey Pat, not that blemish, it was the line I noticed between the bore and the G stamp.... but after looking at it closer it appears to be just a fine surface scratch. I wont worry until the block is cleaned up & magnafluxed...
