Hyatt Bearing Replacement Options
Posted: Mon Aug 04, 2025 12:06 am
by dr1960
Looking for recommendations on replacement options for the rear axle outer Hyatt bearings. Anyone have experience with the cartridge type timken bearing options? I see a couple of different options that don’t require modifying the axle housing. Expensive but seem like an easy install and pretty maintenance free. Thoughts?
Thanks, David
Re: Hyatt Bearing Replacement Options
Posted: Mon Aug 04, 2025 6:34 am
by Jerry VanOoteghem
The best option I'm aware of are the floating style hubs.
Posted: Mon Aug 04, 2025 8:06 am
by John.Zibell
Or find good used original bearings. They are out there.
Posted: Mon Aug 04, 2025 9:44 am
by Oldav8tor
I installed floating safety hubs. Sure, you have to trim a little off the axle tube but I think it's worth it. It transfers some of the weight off the axle and has the added advantage that if your axle should break, the wheel stays on the car.
I also replaced my axles when I installed the safety hubs - they were scored in a couple of places by the Hyatt bearing's cage and I thought the scoring could be a point of failure later on.
Posted: Mon Aug 04, 2025 11:39 am
by Will
I also installed floating safety hubs, Or should I say Gater Gould in Alabama did, I like them. The only issue for me is I have to use shims on my axles so you have to make sure your lined up perfect when putting the hub back on or your going to have to fish out the shim from inside the bearing. In 15 years I have replaced both the inside and the outside seals once which very easy to do.
Posted: Mon Aug 04, 2025 2:27 pm
by Kevin Pharis
I ran a set of ball bearing replacement cartridges years ago. They were great, slipped right in and didn’t have to grease em. The ones I had required trimming of the axle tube ends, same as safety hubs. After a few years I pulled the rear to build into a Ruckstell, but couldn’t get the bearing cartridges out. After much effort I had found that the axles had deformed at the contact point with the outer bearings, causing a raised lip to form under the radius of the bearing. With no way to remove the raised material, I was forced to cut the end of the axle tube off just inside of the bearing cartridge to disassemble. I currently run safety hubs in both my cars
Posted: Mon Aug 04, 2025 4:06 pm
Kevin Pharis wrote: ↑Mon Aug 04, 2025 2:27 pm
A friend of mine had a similar experience, however, in his case, the deformation of the axle shaft eventually lead to a fracture.
