Why do we magnaflux and what is magnaflux?
Posted: Thu Aug 07, 2025 7:17 pm
All Joking aside; hanging a crankshaft up and hitting it with a hammer is not a true test in relation of it being cracked or not .
If I had that skill to know what a cracked part sounded like, the crack detection suppliers would be out of business.
The reason for crack detection or "Magnalfux," being a trade name like Band-Aid or Kleenex represents a big part of the engine rebuilding process.
There is a dry version where user has a electrified tool/magnet with a north and south pole that when placed on flat one dimensional parts, the user dusts iron powder over area to be checked, if part is cracked the powder which is magnetic will get drawn into the void highlighting crack. as seen in picture of water outlet cracked to serial number.
There is also a wet mag machine used for 3 dimensional objects such as crankshafts and cylinder heads, axles, etc.
The part to be checked is placed in the machine between copper pads to recreate North and south of a magnet, thereby when the part is charged through the machine causing part to become magnetized. Then there is a hoop that is passed over each of the rod and main journals to charge around the circumference of the part in question. See second photo.
The part is doused with a non-flammable liquid solution that has luminescent magnetic powder in it.
When the part becomes doused with the solution, the magnetism of the part will attract the iron particles of the solution to the crack.
If there are cracks they will immediately be highlighted by using the black light .
If you'll notice, picture of the crankshaft being highlighted with a fine green line ,as this is the crack in the crankshaft.
What I have mentioned above is for magnetic parts .
For non ferrous,non metallic parts there is the dye test which is done by spraying the part with a green dye that will seep into the crack over time and then a developer spray is used to highlight the area in question.
This procedure is more time consuming and is quite messy.
Above is general description of three methods of crack detection.
A good machine shop will perform these steps so you don't have this result of broken parts as you may notice that this crankshaft is broken, in a newly rebuilt engine.
