Zenith carburetor for T Model
Posted: Sat Aug 09, 2025 5:17 pm
by tmodeldriver
I recently purchased a side draft Zenith carburetor that is configured for the Model T. It is straight through construction and has patent dates of 11/29/08 and 6/27/18. It seems to be a solid, well made unit. I'm wondering if any of you guys have experience with these carbs and have anything pro or con to say about them. All comments are welcome. Thank you in advance. Bob
Re: Zenith carburetor for T Model
Posted: Sat Aug 09, 2025 9:23 pm
by ModelTWoods
I (and you) can only hope that the pot metal venturi is uncracked and intact. Most I see for sale are unusable without replacing the venturi which has to be custom made, because they are not available through the vendors.
Posted: Sun Aug 10, 2025 10:39 pm
by Reno Speedster
I have one (for which I made a new brass Venturi) but I have not put it in a car. I was planning on putting it on the speedster I am working on along with a Z head. But, I found a Rajo BB for that car. I thought of putting it and the Z head on my 22, but it runs great now and I am loathe to mix things up. The Zeniths are supposed to be good carbs and were used on a lot of quality cars. Adjustable main jets available for them.
Posted: Mon Aug 11, 2025 10:29 am
by tmodeldriver
Thanks for your replies, Gents. The venturri in mine is not pot metal. Looks like someone made a steel or iron one for it in the past (magnetic). I see evidence that the choke plate has been removed and reinstalled. Maybe I got lucky. I'll probably replace a sway-back NH with it somewhere down the road and see what happens.
