Rebabbit Block
Posted: Mon Jul 01, 2019 8:03 pm
by Danny Carstensen
Looking to have my block babbit redone. My 22 has .016 end play & no shims left on the rods.Thinking of grinding the crank .010 under , pickup rods from a supplier. The block is std bore with no ring groove. Hone and ring the pistons. Not to many left doing the babbit thing.Can't seem to contact Andy Loso. Who else does babbit within a reasonable distance?
Dan (Southwest Minnesota)
Re: Rebabbit Block
Posted: Mon Jul 01, 2019 8:14 pm
Model T engine bores don't get a ring groove as the top compression rings goes to the top of the bore.
Joe Bell, Kevin Prus or Jack Putnam are close.
Re: Rebabbit Block
Posted: Mon Jul 01, 2019 8:22 pm
by Danny Carstensen
Thanks Steve. Where are these men located?
Re: Rebabbit Block
Posted: Mon Jul 01, 2019 10:31 pm
I believe in Ohio.
Re: Rebabbit Block
Posted: Mon Jul 01, 2019 10:39 pm
by Jack Putnam, in Ohio
I would be happy to Babbitt your block, I've 30 years experience, did the T-100 project for Ford Motor Company, work for the Henry Ford Museum and a few hundred other T engines using KRW equipment. I only do Model T engines, none other. I'm located in NW Ohio!
Re: Rebabbit Block
Posted: Tue Jul 02, 2019 6:28 pm
by Sean Butler
Lookin' good, Jack! Do you bore your own rods as well and if so, what sort of setup do you have?
Re: Rebabbit Block
Posted: Tue Jul 02, 2019 7:43 pm
by Danny Carstensen
Thanks for all the information. Andy just called me, he's been pretty busy. Thanks again
Re: Rebabbit Block
Posted: Tue Jul 02, 2019 8:57 pm
Sean: Yes I bore my own rods. They are set up on a milling machine, then bored to desired size.
Re: Rebabbit Block
Posted: Sun Jul 07, 2019 12:24 pm
by Sean Butler
A Like Arnold Small.jpg (11.13 KiB) Viewed 5312 times
Re: Rebabbit Block
Posted: Sun Jul 07, 2019 3:32 pm
by Joe Bell
I deliver to hershey every year to East coast buys, Joe
