Body to Chassis Pads
Posted: Thu Aug 14, 2025 1:53 pm
by Campbell Tellman
Hey All,
After removing the body to repair it I now cannot remember where the pads go. I have new dust shields and I don't see much info in the Ford Service Manual.
Can anyone advise me?
Thanks,
Campbell Tellman II
1916 Ford Touring Car
Beaufort, NC
Re: Body to Chassis Pads
Posted: Thu Aug 14, 2025 2:15 pm
by Erik Johnson
When your 1916 touring originally came from the factory, there were no pads between the body brackets and the chassis.
If there were pads when you removed the body from the frame, those would have been added by someone at a later date.
Posted: Thu Aug 14, 2025 2:54 pm
by big2bird
You may have had shims to adjust door openings.
Posted: Fri Aug 15, 2025 12:23 pm
by John_Aldrich
Erik Johnson wrote: ↑Thu Aug 14, 2025 2:15 pm
I used an old inner tube that I cut up and used between the body brackets and the frame on my 1915. No noise at all...
Posted: Fri Aug 15, 2025 1:17 pm
Hot rodders use them to reduce vibrations. Old tubes work too
Posted: Fri Aug 15, 2025 2:19 pm
by Shannon_in_Texas
Posted: Fri Aug 15, 2025 3:14 pm
by Campbell Tellman
Thanks to all that responded. I looked at the pads today and they are about 1/2 inch thick rubber. There is a longer pad under the radiator. I have done a lot of work on the body and the doors are perfect. I will check the frame rails to see if I need the pads to keep the body level.
Campbell Tellman II
1916 Ford Touring
Beaufort, NC
Posted: Fri Aug 15, 2025 8:53 pm
Introducing a 1/2" pad under the body would necessitate raising the radiator too so the hood would still fit. !/2" is overkill. If the aim was to stop noise/squeaks 1/8" would do. Best to use insertion rubber with the fabric in the rubber That said the only place I have ever used any rubber is under the pan ears on just one of my Ts.
As others indicated, sometimes shims are used on the frame mounts to adjust door gaps. The need to do so indicates the frame is no longer straight.
Posted: Fri Aug 15, 2025 10:40 pm
by Erik Johnson
I would skip installing rubber pads or shims.
